04-07-2020, 01:33 AM | #1 |
60-66 extra small stuff lots of it
Corona virus aided clean up. Here’s a bunch of stuff that that someone might need. more parts to come, the deeper I go into cleaning. Price as listed plus shipping and PayPal fees. Bundle for better prices.
1 horseshoe engine mount 60-62 $80 sold 2 alternator and regulator harness 60-62 $20 3 Under dash harness 60-62 $45. Sold 4 GMC gauge cluster $25 5 64-66 cluster lens $10 6 Right door actuator/latch 64-66 $20 7 engine harness $25 8 water pump pulley $10 9 water pump pulley $10 10 Crank single groove $10 11 cab mount frame brackets $20 pair sold 12 fender seal $10 13 cab mount fasteners $10 sold 14 clear parking light lens and buckets $20 pair 15 amber parking light lenses and buckets $20 pair 16 inner fender brace brackets $15 pair 17-18-19 coil brackets $3 each 20 heater controls 60-63 $20 21 clutch pedal 64-66 $20 22 latch $20 23 latch $15 24latch $20 25 taillight housings $15 pair 26 air vents $10 pair 27 jack hardware $25 set 28 door window guides $20 pair 29 GMC parking lenses $20 pair 30 door handle$3 31 accelerator pedal hardware $15 32 blue seat belts(2) from 66 $40 33red seat belt (1) from 66 $20 34-35 grill brackets from 64-66 $25 each 36 center support bracket for 64-66 grill $10 37 hood guide $25 38 hood latch $25 39 right side radiator support cover $20 40 glove box door ( not for sale at the moment) 41 brake pedal assembly 64-66 $30 42-43-44 fender seals $10 each 45 wiper actuator mechanism $20 46 wiper motor $20 47 horn (not for sale yet) 48-49-50 $25 each (I’m keeping a driver side) 51 heater control/cable and duct $25 52-53 heater box $50 (I’m keeping one) 54 instrument cluster no bezel $20 55 instrument cluster complete $60 56 custom cab corner trim both sides as you see $30 Last edited by tchevs; 04-16-2020 at 10:30 AM. Reason: Parts sold |
04-07-2020, 01:36 AM | #2 |
Re: 60-66 extra small stuff lots of it
More pictures
04-07-2020, 01:39 AM | #3 |
More
04-07-2020, 01:44 AM | #4 |
More
04-07-2020, 11:18 PM | #5 |
I’ll take the horseshoe mount, and under dash harness as a package, what would shipping be to 67601
04-08-2020, 12:03 PM | #6 |
C10 CLUB Y QUE!
how much for the heater delete plate?
04-08-2020, 03:58 PM | #7 |
04-08-2020, 04:00 PM | #8 |
04-08-2020, 04:22 PM | #9 |
That will work, pm sent
04-08-2020, 04:30 PM | #10 |
Pm returned
04-09-2020, 06:53 PM | #11 |
Active Member
I see someone is interested, but can I be next in line for the heater delete plate(s) that go on the firewall?
04-09-2020, 07:18 PM | #12 |
Dtkarst your items shipped tracking is in your PM
04-09-2020, 07:20 PM | #13 |
04-10-2020, 10:34 AM | #14 |
any more heater delete plates? I could use one for my 64
04-10-2020, 04:54 PM | #15 |
Active Member
04-10-2020, 08:35 PM | #16 | |
Sick5 didn’t respond so you’re next in line. It would probably fit in a flat rate envelope, if you’re ok with it in an envelope let’s do $40 shipped to you, to cover shipping and PayPal. Tony |
04-10-2020, 08:41 PM | #17 |
I might remove the ones on my 62, but not going to happen at the moment. Just curious why these things are a hot item? I have noticed that a few people are looking for them. Are the heater boxes from the 60-62 better or something?
04-10-2020, 09:19 PM | #18 |
not sure what the craze is. im not going to run a heater so that's why I need a set. im not sure if they are different from the 60-63 to the 64-66 let me know if you want to get rid of a set.
04-10-2020, 09:41 PM | #19 |
I was actually reading up on it to see if I can use one of those 64-66 heaters on the 62 because the core on the 62 is bad. If it is a possibility I’ll get back to you
04-10-2020, 10:56 PM | #20 |
04-11-2020, 08:43 AM | #21 |
Active Member
04-11-2020, 09:03 AM | #22 | |
Active Member
Thanks again for your help. |
04-11-2020, 10:51 AM | #23 |
Ok, I can see why people want those. I couldn’t go without a defroster here, no matter the season. It can be a nice sunny day, next thing fog rolls in. You won’t see shstuff without a defroster.
Joe, PM sent |
04-11-2020, 12:29 PM | #24 |
C10 CLUB Y QUE!
go ahead i pass on 30
04-11-2020, 08:09 PM | #25 |
But Found Her 25yrs Later!
Do you know if the water temperature sensor works and is for our generation trucks?
