03-10-2004, 09:22 PM | #1 |
WTB: 350 chevy heads
I need to buy a set of 350 heads for an '81 camaro. Dont need to be complete, valve size isnt a huge issue either. Thanks
2003 Yamaha Blaster for sale : $1900 OBO |
03-10-2004, 09:41 PM | #2 | |
Bloo
i may have a set-- if i still have them they are 993s, 76 CC chamber, 1.94/1.5 valves, need some valve work done
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
03-11-2004, 01:04 AM | #3 |
Ive got some swirl ports Local shop called them early model vortecs Dont know about that buy the intake runners look just like a tec Head But uses a 12 bolt intake with the two center holes straight up.
03-11-2004, 01:30 AM | #4 |
just put some 305 heads on there and bump the compression and gain some power.
'67 c10 350/th350 |
03-11-2004, 01:38 AM | #5 |
" SHOW ME"
ive got a set of stockers , you would probably want to tank them tho , id go to the junk yard and just find an ole truck or car with a 350 in it and pull em , shouldnt run ya more than 50 bucks for a pair , careful with the 305 heads , they are a good power maker but if theyre not right youre gonna get a crappy spark knock
03-11-2004, 03:23 AM | #6 |
got a friend with some forsale, i'll get you pics and some numbers, they are rebuilt though, she doesn't have the info, they were her husbands and he's in jail, she wants $100
03-11-2004, 11:32 PM | #7 |
heads
Stay away from heads with last 3 numbers 624's. I have a set that have cracked or head gasket is gone and I can think of 3 other 350's that died with those heads. They are junk. A guy at a motor rebuid shop said they seldom rebuild them. Says you get a sticky thermostat and get the motor hot once and they are toast.
03-11-2004, 11:44 PM | #8 |
Careful, they attack...
I got a set of bare casting truck heads with 1.72 intake and 1.5 exhaust. Had them tanked and checked. will let them go cheap. No accessory holes, so they won't work for what I want to do. They are disassembled now, but I have the valves, springs retainers, and locks. Needs a couple new guides and a valve grind.
03-12-2004, 07:02 PM | #9 |
I will give you some 305 head just come and get them.
Or i will sale some 882 heads
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
