09-24-2020, 03:03 PM | #1501 |
Re: What did you do to your truck today.The 3rd chapter
Wow! That looks fantastic. Great save.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
09-24-2020, 03:54 PM | #1502 |
Nice work! Where did you purchase your windshield? Locally or ordered and shipped?
09-24-2020, 04:20 PM | #1503 |
I tried ordering a windshield from Summit, but they were backordered for two months out, so I bought one locally. Paid $140 for it. I'm a little annoyed that it is made in China, but that's the way it goes these days. At least it has a nice green tint.
09-26-2020, 11:59 PM | #1504 |
Assembled my new bed,
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2015 Chevy Tahoe LTZ 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 |
09-27-2020, 12:10 AM | #1505 |
Replaced the rear main seal and oil pan gasket. Had to contend with a snapped off bolt the PO left for me. Bought a right angle drill from Harbor Freight to access the hole because it was right above the cross member. Hammered a Torx bit into it and fortunately it unscrewed. I felt like I won the lottery when that happened. The PO also used RTV on the entire rear main seal, so I had to make a scraper to very carefully clean out the passageway above the crank.
09-27-2020, 02:11 AM | #1506 |
My hood was paroled. All I did is write a check.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-27-2020, 11:58 AM | #1507 |
Looks great
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
09-27-2020, 01:22 PM | #1508 |
Sometimes checks are good.
09-27-2020, 02:19 PM | #1509 |
I have the wiring mostly completed and getting things buttoned up.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
09-27-2020, 05:07 PM | #1510 |
Today I repaired the broken studs on my turn signal housing
Ang gave them a good scrubbing |
09-27-2020, 08:00 PM | #1511 |
Ya I keep writing checks my body can’t cash . Started on the drivers side rot today
09-27-2020, 08:03 PM | #1512 |
Changed my electric fuel pump on ol Samson, it was a pain to get to inside the frame rails with the exhaust but it’s done now.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
09-27-2020, 10:10 PM | #1513 |
Finished replacing the heater core. Installed the inner fender and hoses.
09-28-2020, 12:13 PM | #1514 |
Those heater cores are a ***** to get out! Any tips/secrets you could share?
Incapable of not thinking about my truck at least every other minute |
09-28-2020, 12:31 PM | #1515 |
It sure was a lot of work. I'm not sure I did anything unique on this repair. I followed various pieces of guidance I found from searching the forum. I used pieces of wood to support the hood while the hinge was removed. I removed the inner fender (I had already removed it to do some rust repair and paint). I had a hard time separating the heater box from the firewall because the previous owner had glued it on there with an excessive amount of RTV silicone. I purchased a copper/brass heater from npdlink.com based on lots of comments about the aluminum cores not fitting. I purchased a heater box seal set from GMC Paul's and glued the round seal and air box seal to the air box with weatherstrip adhesive.
09-28-2020, 01:20 PM | #1516 |
Set up for a new carburetor install. Area ready
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
09-28-2020, 01:44 PM | #1517 |
Finally changed throttle out to a cable. Decided to add some bling, deluxe pedal assemblies while I was at it. And new floor mats to try and hide the hole in the carpet left by the floor mounted pedal
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
09-28-2020, 02:31 PM | #1518 | |
in the boxes. One tested good and was an easy install with the whole front end off the truck. I hope I never have to go back in there. Tom
09-28-2020, 05:33 PM | #1519 |
Drivers side kick my butt today . I’m used to having the passenger side worse than the drivers it this was a farm truck. So I guess all the slop ended up there. Made all the patches myself most likely would have been harder with aftermarkets also put two coats of pour 15 on the passenger side.
09-29-2020, 05:26 AM | #1520 |
Looks great!
09-29-2020, 05:01 PM | #1521 |
I rented a hot power washer and de-greased the drive train and engine bay. PO's did not have a functioning PCV system and oil was misting everywhere. Now I can finally proceed with my engine update project!
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke 2007 BMW X3 2020 BMW 540xi 1995 Harley FLSTC |
09-30-2020, 07:30 PM | #1522 |
Did some touch up painting and painting some miscellaneous parts. I went ahead and installed the fresh air inlet doors
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
09-30-2020, 09:55 PM | #1523 |
Installed Redhead power steering box. Can't wait to take it on the highway.
10-01-2020, 09:38 AM | #1524 | |
Tried engine cleaner but it really didnt work at all. The gunk stuff they must have changed the formula
10-01-2020, 06:10 PM | #1525 |
Today’s fun been a long road with this 68 . It’s all in primer now
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 10-01-2020 at 06:20 PM. |
