Old 02-09-2016, 01:59 AM   #151
azdude1964
azdude1964's Avatar
Re: 66 Pro Street Build (Domeringer)
looking good . Do you plan on welding the patch back in that you cut out of the back wall.
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline   Reply With Quote
Old 02-09-2016, 07:12 AM   #152
Gary V
Active Member
Gary V's Avatar
Oh yea! That back panel is very beat up to the point where the lower window seat is bent inward from stuff sliding into it over the years. Got something trick in mind...
Best regards,
Gary
DOMERINGER BUILD
Gary V is offline   Reply With Quote
Old 02-25-2016, 05:52 PM   #153
azdude1964
azdude1964's Avatar
update please SIR.
Old 02-25-2016, 06:43 PM   #154
ptc
ptc's Avatar
Gary, great build man! so much information too, thanks for all that you. Also glad to see your recommendation for Ron Fournier, read that book myself so many years ago and hes is a great talent to the fab industry.
Working on my roll cage right now too and very frustrated with the NHRA rule BS.... I decided to keep mine more street than strip by keeping my cab removable, but it will be roll cage safe. (whether or not the NHRA tech board believes so).
Anyway great job, keep it up!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 02-25-2016, 07:43 PM   #155
Gary V
Active Member
Gary V's Avatar
Originally Posted by azdude1964 View Post
update please SIR.
Not much to post... got a little side tracked with my brothers turbo fox body. Shortened and back braced his 9" rear... wish there was more time for fun stuff. Will go back to work on the truck Saturday and Sunday and post some updates Sunday night.
Thank you! Yea that NHRA rule stuff can be a pain in the butt. The faster you want to go the more so. I'm liking the Outlaw events run without the NHRA sanctioning more and more.
Hummm had a chance to read a post I put up early one morning... seems I got my tigs and migs mixed up... here's the corrected version.
Very good! I think you will enjoy the book. Ron Fornier has been around for a long time and does awesome work. A cold start can usually be attributed to technique, amperage and wire feed speed. Try turning your machine up and starting a little ahead of your stop position and coming back... you can weld hotter if your not traveling so far. It can be difficult to weld heavy structural steel with the low cost mig machines on the market today. They are more suited for bodywork than doing structural. The new small inverter mig machines have a low duty cycle (The number of minutes you can weld in 10 minutes expressed as a percentage, eg. 20% duty cycle = 2 minutes in 10 where the machine is holding the current you originally set) We have a 300 amp Lincoln mig running .041 wire at work... there is no cold start.
Not a big fan of mig welding unless I have a big machine at my disposal. Having been an arc welder for many years... in my worn out flash burned eyes the penetration you get with arc is far superior to mig. It does take some crazy skills to weld all positions... which is why mig is so popular.
All of the framework on the truck aside from the 4130 tube is 1/8 wall.
Best regards,
Gary
DOMERINGER BUILD
Old 02-29-2016, 09:41 PM   #156
Gary V
Active Member
Gary V's Avatar
Small update... finished the main hoop cross bracing. Hope to get the seats set in place this coming weekend.
Best regards,
Gary
DOMERINGER BUILD
Old 02-29-2016, 11:21 PM   #157
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Ha! Funny about the corrected version of your post!
I was assuming that this was what you originally meant...Initially I was pretty confused, but was pretty sure that you may be having an adult beverage moment...LOL!
All good!!!!
Modges'66 is offline   Reply With Quote
Old 03-01-2016, 01:05 AM   #158
azdude1964
azdude1964's Avatar
awesome gonna start tweakin mine just dropped off the 540 at the machine shop
Old 03-14-2016, 08:24 PM   #159
Gary V
Active Member
Gary V's Avatar
All good!!!!
Funny it all made sense when I wrote it in the morning LOL.
Saw your post in the racing forum and am very interested in where your taking the beast. Will post there for details. Big blocks rule! It's a real struggle for me to go this LS route. The more I read about the LS and big horse power the more uncertain I become... we'll see.
A little progress... bought a dated harness for mock up. The final purchase will be a for a 7 point. Still lots of fab work to go.
Best regards,
Gary
DOMERINGER BUILD
Old 03-15-2016, 07:03 PM   #160
chad64chevy
chad64chevy's Avatar
looking good, Gary! question how are you going to weld behind the bars between the back wall?
chad64chevy is offline   Reply With Quote
Old 03-19-2016, 05:51 AM   #161
Gary V
Active Member
Gary V's Avatar
Thanks Chad, Very soon the cab will be removed for the last time and the cab portion of the cage will be finish welded. Then the cab will go back on and the body/floor will be finished around it.
Off to the shop... updates soon
Best regards,
Gary
DOMERINGER BUILD
Old 03-19-2016, 08:10 PM   #162
azdude1964
azdude1964's Avatar
looking awesome I'm taking notes
Old 03-27-2016, 09:52 AM   #163
Gary V
Active Member
Gary V's Avatar
Very good thanks!
Ok been pretty busy with it and figured it's time for an update! Bent up a funny car cage and removed it for time being. Maybe some day I will put it in permanently... not good for the dome for street use. Think I will be happy with the 8.5 trap time... but who knows I may win the lottery and want to go faster LOL
Also repositioned and changed the seat mount after I discovered that the funny car cage was a little too close to the top of my head.
Started working on the rear frame fab
Best regards,
Gary
DOMERINGER BUILD
Old 03-27-2016, 12:41 PM   #164
mud.man.rj
mud.man.rj's Avatar
Don't worry about the cage, as you get older you shrink and get shorter, so sooner or later you will fit
Really nice work, coming together as a killer build.
Waiting for more and more.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 04-09-2016, 07:07 PM   #165
Gary V
Active Member
Gary V's Avatar
LOL yea that gravity thing!
Well still working on the chassis... some progress
Replaced the rear cross member after finding that at full bump stop the driveshaft would just tag the loop... didn't like that thing anyway.
Best regards,
Gary
DOMERINGER BUILD
Old 04-09-2016, 08:35 PM   #166
mud.man.rj
mud.man.rj's Avatar
Gets nothing but better each post, so what are you running for windows later, glass still or lexan.
5.0 4spd std.
7" lift w 35's.
Old 04-09-2016, 10:47 PM   #167
tinydb84
tinydb84's Avatar
I love your posts. Truly a work of art.
David
Instagram: myfabguy
Old 04-11-2016, 05:56 AM   #168
Gary V
Active Member
Gary V's Avatar
Thank you Guys! Sorry missed your question! Lexan side and back
Best regards,
Gary
DOMERINGER BUILD
Old 04-13-2016, 09:24 PM   #169
Gary V
Active Member
Gary V's Avatar
Little update
Best regards,
Gary
DOMERINGER BUILD
Old 04-13-2016, 10:14 PM   #170
Winmon
Winmon's Avatar
Really nice work, very cool build
Winmon is offline   Reply With Quote
Old 04-16-2016, 06:45 PM   #171
Gary V
Active Member
Gary V's Avatar
Thank you my friend... Ok finished up the rear end tube work. Lots of finish welding to do once I get the cab off. Next we move back into the cab interior to work on the steering end. One more pic of the back end... should handle anything I can afford to throw at it!
Best regards,
Gary
DOMERINGER BUILD
Old 04-16-2016, 07:42 PM   #172
Ronzo
Ronzo's Avatar
I love the craftsmanship, one of my favourite builds to follow.
Ronzo is offline   Reply With Quote
Old 04-17-2016, 12:04 AM   #173
66ChevyMax
66ChevyMax's Avatar
Awesome stuff
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 04-17-2016, 10:55 AM   #174
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Wow, that is a beefy chassis!
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 04-17-2016, 01:27 PM   #175
testerdahl
Subscribed for sure. I'm a freelance automotive journalist and write for Truck Trend and Pickuptrucks.com Can't wait to see the finished product! I hope you are up for an interview when it is all done since I'd like to write this build up as a story.
testerdahl is offline   Reply With Quote
66 c10, drag truck, pro street, twin turbo ls1
