Old 09-18-2019, 04:28 PM   #26
solidaxel
solidaxel's Avatar
Re: 6.0 swap with 4L60E not shifting
Do you have a trans shop in the area?
They have capabilities of plugging into your trans and "telling" it what to do
They can tell what it is not doing!
The problem needs to be isolated, PCM, Wire harness. or trans
I just went through a "code" problem with my 4L60E and not fun!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-18-2019, 05:42 PM   #27
gbenfield
gbenfield's Avatar
Trans shop is the next stop if internal wiring harness doesn't get it. Thanks
gbenfield is offline   Reply With Quote
Old 09-24-2019, 08:29 PM   #28
YoungPup1977
Originally Posted by gbenfield View Post
Yes, same codes, I've ordered a new internal wiring harness for the tranny, to eliminate that, should be here in a couple of days
In a previous post you indicated the transmission you are going to use "worked" in the donor vehicle, so if this is true how could the internal wiring harness be bad and you also stated you bench tested end to end.
Have you considered replacing the Vehicle speed sensor as mentioned in earlier post.
YoungPup1977 is offline   Reply With Quote
Old 09-24-2019, 09:31 PM   #29
gbenfield
gbenfield's Avatar
VSS is working or I wouldn't be getting MPH reading through OBD port as stated earlier
Old 09-30-2019, 04:48 PM   #30
gbenfield
gbenfield's Avatar
I've got gears, wires in plug were 180 out. Thanks to everyone that gave suggestions
Old 09-30-2019, 11:21 PM   #31
YoungPup1977
the ol 180 out on the wires will do it every time....glad you got it fingered out...
