04-29-2017, 11:14 PM | #1 |
My 1980 Silverado build thread
Hey guys and gals. Just wanted to start a build thread for my 1980 short bed. So here is the history.
The truck is a 1980 Short bed Silverado 2WD that I bought from my Father in-law. The truck had been stored in is shop for the past 10 years. It has 80,000 miles and was pretty much bone stock minus the .243 bullet hole in the floor. It still has the functional 8-track player . So far I have pulled out the blown 305 and installed the motor I originally built for my 69 C10. I do need some help with the motor but ill get that in a later post. Here is the stats so far. SBC 383 BORE: 4.030 STROKE: 3.750 DECK HEIGHT: .025 CYLINDER HEAD VOLUME: 72CC HEADS: 190CC RUNNERS HEAD MATERIAL: ALUMINUM GASKET THICKNESS: .032 COMPRESSION RATIO: 10.03:1 PISTON: FLAT TOP SINGLE VALVE RELIEF CAM: COMP CAM XE294H TIMING CHAIN: DOUBLE ROLLER ROCKER ARMS: ALUMINUM 1.5 DIST: MSD PRO BILLET/MSD 6AL INTAKE: RPM AIR GAP CARB: 750 HOLLEY DP MANUAL CHOKE TRANS:TH350C CONVERTER:3000 STALL HEADERS: 1 5/8 LONG TUBE EXAHUST: 3" WITH X-PIPE MUFFLERS: 3" BORLA OFFSET/OFFSET GEARS: 3.08:1 (I think) Here is my 69 going to a new home. Day I brought it home. Old 305. Interior. How i found it. Getting the motor ready. Motor going in. My helper. Motor in and all cleaned up.
1980 TURBO C10
(GRUMPYC10 ON INSTAGRAM FOR MORE PICTURES) |
04-29-2017, 11:24 PM | #2 |
Re: My 1980 Silverado build thread
My plans as of right now....
3/5 drop Weld S71-B wheels Detroit true trac 3.73:1 Gears Fi-tech 600hp Power adder EFI Change to a smoother idle cam. Replace the front windshield. Change to blue and white paint scheme.
1980 TURBO C10
04-30-2017, 10:49 AM | #3 |
05-01-2017, 04:21 PM | #4 |
What a find! Looks like a great truck. Nice job on the engine bay clean up.
09-15-2017, 09:36 AM | #5 |
Time for an update......
Eaton truetrac installed, 3.73:1 gears installed, Disc brake conversion done, 4" drop on the rear done, 3.5" drop on the front done. 3" x-pipe with Borla mufflers installed. Weld wheels on the front (been waiting on the rear wheels since June.... Weld is slow) Fi Tech 600hp Power adder is going on this weekend. So hopefully she will be screaming down the road soon....
1980 TURBO C10
(GRUMPYC10 ON INSTAGRAM FOR MORE PICTURES) Last edited by SLDPULR; 09-18-2017 at 09:27 AM. |
09-18-2017, 07:06 AM | #6 |
That thing's gonna be squirrelly. Nice truck!
09-18-2017, 09:19 AM | #7 |
Its all over the road with the factory tires on the back. I have M/T tires for the back but no wheels to put them on. I've been waiting since June for Weld to build them for me.
1980 TURBO C10
(GRUMPYC10 ON INSTAGRAM FOR MORE PICTURES) Last edited by SLDPULR; 09-18-2017 at 09:26 AM. |
09-18-2017, 10:41 AM | #8 |
VERY NICE!!!! I've always loved the 1980
What rear disc brake kit did you use? Parking brake or no? Do you know what the rotors are from, for replacement? That 383 is going to be awesome!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD |
09-18-2017, 11:03 AM | #9 | |
Check out this link http://67-72chevytrucks.com/vboard/s...d.php?t=746646
1980 TURBO C10
03-09-2018, 04:35 PM | #10 |
Looking good, did you get your Weld wheels in the rear?
02-26-2019, 06:19 AM | #11 |
Any updates?
77 C10 Silverado SWB - LS Swap, mechanical resto-mod 05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e |
04-10-2019, 01:08 PM | #12 |
Well I guess I should do an update on the truck. I have been spending most of my time over on the turbo forum trying to get all the bugs worked out and the truck is pretty much done now.
So I blew the 383 to pieces one day. (long story about FiTech that I wont go into) Found me a 6.0 LQ4 out of a 2006 Yukon Denali. Yanked out the old 383 and started getting the motor ready for paint.
1980 TURBO C10
04-10-2019, 01:12 PM | #13 |
Fast forward a few months and I installed a LJMS stage 2 turbo cam package with push rods and valve spring, Got some up and forward turbo headers and built my hot side and exhaust.
Edit: Sorry for the sideways pictures. Just pick your monitor up and turn it sideways for the full effect. I will fix the sideways pictures tonight on my laptop. My work computer wont let me turn them to the correct orientation.
1980 TURBO C10
(GRUMPYC10 ON INSTAGRAM FOR MORE PICTURES) Last edited by SLDPULR; 04-10-2019 at 01:28 PM. |
04-10-2019, 01:18 PM | #14 |
Next up was the cold side.
1980 TURBO C10
04-10-2019, 01:21 PM | #15 |
Next was a holley High Ram, Deka 80lb injectors, Dual 400lph pumps, Holley HP EFI system, 4" down pipe, fender exit exhaust, and other odds and ends.
1980 TURBO C10
04-10-2019, 01:22 PM | #16 |
Nice ride, I will follow along.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
04-10-2019, 01:26 PM | #17 |
Over the past few weeks everything has really started to come together. I have the truck tuned and driving awesome. I relocated the coils and have started cleaning up the engine bay. I have the truck entered at the C10 Nationals at Texas motor speedway in may so its been a mad dash to clean it all up.
This has all been a learning experience for me and I have had a ton of help from other forums and friends. If anyone has any questions or wants other pictures let me know and I will post them. Thanks for following along.
1980 TURBO C10
04-10-2019, 01:34 PM | #18 |
1980 TURBO C10
04-10-2019, 01:47 PM | #19 |
dayummmm
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
04-10-2019, 02:35 PM | #20 |
Looks good man. Why Holley EFI vs GM PCM and HPT?
04-10-2019, 04:02 PM | #21 |
I really liked the user interface of the Holley and the built in digital dash. I have a Megasquirt system on my wife's car and tuner studio was ok. Ive never messed with HP tuners but I do know they offer a very nice system but I guess the main reason I went with holley was the harness. I think they had the nicest quality harness. Plus all of the built in ICF's are a huge time saver.
1980 TURBO C10
04-27-2019, 05:13 PM | #22 |
Amazing.
Thomas Retired Marine, OIF & OEF Vet. My Project: http://67-72chevytrucks.com/vboard/s...d.php?t=771429 |
04-30-2019, 12:23 AM | #23 |
Talk about a full house. That engine compartment is full. Looks nice.
05-01-2019, 01:29 PM | #24 |
ill keep an eye out for it at the show!
05-01-2019, 02:45 PM | #25 |
Wow That is a Mint V22 Option 1980 truck! There are LESS & Less around.
1979 Pontiac LeMans 231/Th350 1982 Chevrolet Silverado K10 6.2 Diesel/700r4 1984 Buick Regal Limited Sedan 4.3 V6 Diesel/200r4 (Hens teeth rare) 1991 Chevrolet Silverado K2500 5.7/700r4 1999 Chevrolet Base LS K2500 6.5TD/4L80e |
