Old 03-18-2007, 01:22 AM   #1
mateo1279
mateo1279's Avatar
Tranny Question
(My first post)
Anyone ever have a 350 auto leak only when it's on a hill? I have been commuting with my 62' for about a year, but have always parked it on a flat surface. I recently moved and have now parked it (for a few weeks) on a slight slant (rear lower the front). I noticed a pool of redish fluid gathering over the course of a day or two, then it stopped. I figure it's the tranny (fluid color, texture and smell) but am open to any imput.
Thank you for the Hand!!!
-Matt
mateo1279 is offline   Reply With Quote
Old 03-18-2007, 09:26 AM   #2
62 short step
62 short step's Avatar
Re: Tranny Question
The seal where the drive shaft goes into the tranny could be bad. Its very inexpensive to change it. I used to have a truck that did this, it didn't matter if it was on a hill or flat.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 03-18-2007, 09:33 AM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Tranny Question
Chevy Fleetside is offline   Reply With Quote
Old 03-18-2007, 10:08 AM   #4
krue
Designated A-hole!
krue's Avatar
Re: Tranny Question
Welcome to the board from South Mississippi! Which way is the truck facing on the hill? The leak spots on a TH-350 are the pan, the front seal, rear seal, shift shaft seal, speedometer bullet seal and gear o-ring, the kickdown cable o-ring and the dipstick o-ring. I may have missed something, I don't remember what seals the vacuum modulator.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 03-18-2007, 10:41 AM   #5
62 short step
Re: Tranny Question
I believe an o-ring does.
1965 c-10
86 chevy c/k 20
Old 03-18-2007, 04:49 PM   #6
mateo1279
mateo1279's Avatar
Re: Tranny Question
It's facing up hill. I'll climb under today and see if I can find the leak, then take a picture. I may need help identifying anything other than the pan.
Thanks again!!!
-Matt
Old 03-18-2007, 06:05 PM   #7
mateo1279
mateo1279's Avatar
Re: Tranny Question
Ok,
Crawled under and saw a few drips hanging off the pan (pic attached) and also the cross member behind the pan. I couldn't really see where the leak orginated as the underside of my truck is messy to say the least! I can tell it isn't where the dipstick tube enters (looked relatively clean), so there is one possible area checked.
But here's a twist. I checked the fluid level... it reads above full. I know the puddle is transmition fluid (reddish) and I know a lot is on the ground, but why would the stick say full??? Am I taking crazy pills.
Thanks again,
Matt
Old 03-18-2007, 06:22 PM   #8
zeitlerusmc
zeitlerusmc's Avatar
Re: Tranny Question
just do the rear seal and a tranny pan gasket. the crossmember is probly soaked with the fluid flying off and collecting on the crossmember while your driving, both gaskets are cheap!
zeitlerusmc is offline   Reply With Quote
Old 03-18-2007, 06:43 PM   #9
krue
Designated A-hole!
krue's Avatar
Re: Tranny Question
You may actually be draining fluid out of your torque convertor by parking on a slope.
www.daveramsey.com
Old 03-18-2007, 07:46 PM   #10
mateo1279
mateo1279's Avatar
Re: Tranny Question
Sounds good! I plan on repacing the pan gasket and rear seal, as both of these seem to be in the areas the drops seem to form at. The pan gasket seems straight forward, and I will post again if I have trouble with the rear seal.
In regards to the torque converter, would I see fluid on it if it were the cause of the leak? (I don't see fluid on it, but I am an amature in the transmition department).
Thank you all and I will update when the repair is complete.
-Matt
1962 Chevy Fleetside
283/TH350
Old 03-19-2007, 12:52 PM   #11
zeitlerusmc
Re: Tranny Question
knock out the cheap and inexspensive stuff first! then if the problem persists then start looking in other directions. sometimes the fix to the problem is the smallest, cheapest part!
Old 03-19-2007, 11:06 PM   #12
mateo1279
mateo1279's Avatar
Re: Tranny Question
Thanks for the tip! I'll start with the pan gasket (and filter while I'm in there)...
-M
283/TH350
Old 03-23-2007, 12:52 AM   #13
mateo1279
mateo1279's Avatar
Re: Tranny Question
Pulled the trans support and pan tonight. 2 questions:
1. I had to stop because of mild thunderstorm. I stopped with the pan and filter off. Will I have any problems if I won't have a chance to put the pan on untl Sunday (3 days)?
2. This is the first time I have done this repair. I attached a pic of the inside of the trans pan. The fluid was red and clear, but there was sludge on the bottom of it. Also, the magnet looked like a roundish coin with spikes. After cleaning it was a smaller square. Is this a symptom of anything bad, or is this normal?
Thank everyone!
-Matt
283/TH350
Old 03-23-2007, 10:25 PM   #14
Chevy Fleetside
Re: Tranny Question
You should put the pan back on even if it is only a few bolts.. Just to keep the moisture out so nothing rusts...
Old 03-24-2007, 12:12 PM   #15
mateo1279
mateo1279's Avatar
Re: Tranny Question
Sounds good! I was worried about that. i ended up going ot around midnight and bolting it up because I ws paranoid!
-Matt
283/TH350
Old 03-24-2007, 08:05 PM   #16
hewlett2002000
hewlett2002000's Avatar
Re: Tranny Question
im lucky to have a shop so i can work through sleet and snow(like texas ever sees snow). i just hope we dont have to move again cause that will be hell now, i have a 62 in peices in the shop, a 84 and a 66 in the driveway, and a 81 burb on the way. im getting quite a collection.
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 03-25-2007, 01:00 AM   #17
mateo1279
mateo1279's Avatar
Re: Tranny Question
Wow, that is a collection! My family and I will be relocating soon to OR. and hopefully get a garage (read:shop!). I am sure my collection will grow slightly at that point.
283/TH350
Old 03-26-2007, 11:58 PM   #18
mateo1279
mateo1279's Avatar
Re: Tranny Question
All Right!
I have everything back together. I had to put in a new speedo cable (old one was thrashed!).
Thank for all the help! I am really happy to have found such a supportive board.
All the best
-Matt
283/TH350
