03-26-2016, 09:59 PM | #1 |
Push rod hold for fuel pump install on BB
On some small blocks I have used a through hole in the front of the block to insert a bolt (etc) to hold the push rod from camshaft up into its channel (instead of using heavy grease, slip strip, etc). Is there such an opening on the front of BBs?
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
03-27-2016, 10:04 AM | #2 |
Re: Push rod hold for fuel pump install on BB
I don't remember one being in the front but there is a plug under the fuel pump hole that you can remove to push back the rod.
03-27-2016, 06:50 PM | #3 |
Just use some wheel bearing grease on the rod, that will hold it for a while.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
04-01-2016, 06:52 PM | #4 |
Thanks hugger - first time I've done a fuel pump on a BB - found the plug. Helpful.
04-01-2016, 09:44 PM | #5 |
I've also used thicker type grease in the past
______________________ www.northeastrodrun.com |
