03-10-2019, 04:59 PM | #1 |
66 c10 Starter Wiring
Where do the 2 starter wires penetrate the firewall?
The red and small purple |
03-10-2019, 05:26 PM | #2 |
Moderator
Re: 66 c10 Starter Wiring
Pic of firewall holes.
03-10-2019, 05:28 PM | #3 |
Yep ive been using this
Not sure still where these 2 wires go thru |
03-10-2019, 05:38 PM | #4 |
Moderator
Do you have a wiring diagram? It will show the plug, hence the size of the hole. - http://webhosting.web.com/imagelib/s...ng%20Schematic
or http://67-72chevytrucks.com/vboard/s...0&postcount=12
03-10-2019, 05:43 PM | #5 |
Yes
I actually went thru the entire manual Nothing very specific Hoping someone could point on the firewall with a pix |
03-10-2019, 05:47 PM | #6 |
Mine goes to the plug to the right of heater box. J.R.
03-10-2019, 06:06 PM | #7 |
Moderator
Are you using the original firewall plug to make the passage thru the firewall?
03-10-2019, 06:12 PM | #8 |
This photo should help what i need
1. Dark blue is oil sender - not using 2. Light green alt water temp - not using 3. White - tach 4. Pink - Ignition coil feed 5. Brown - alternator ignition From starter 6. Purple - from starter (solenoid) 7. Red - 12 volt battery 8. Big red - alternator |
03-12-2019, 12:31 PM | #9 |
still having trouble with this American Autowire kit. any experience with the wiring i described.?
03-12-2019, 04:39 PM | #10 |
tag. Is this the same for the '63s? GREAT firewall pic
03-12-2019, 04:49 PM | #11 |
Why is there a hole for the TAIL LIGHT WIRING in the firewall ?? |
03-12-2019, 04:51 PM | #12 |
i think the brown "alternator ignition" wire goes to the alternator itself.
the small red paired with the solenoid purple goes to the dash harness. yet i havent figured where thru the firewall it goes. help |
03-12-2019, 04:58 PM | #13 |
03-12-2019, 05:00 PM | #14 | |
Adding photo from the kit for reference Last edited by Afirehawk1; 03-12-2019 at 06:42 PM. Reason: Adding photo |
03-13-2019, 01:16 AM | #15 | |
Worth mentioning I have never used this harness, I'm going off the diagram you posted. |
03-18-2019, 03:08 PM | #16 |
Ok i think i figured it out
Suggestions on where to get a 2 wire firewall grommet? |
