03-19-2019, 06:06 PM | #1 |
Ignition switch help please
Currently my keyed ignition switch is located on the crap steering column installed by previous owner.
The old ignition switch is still mounted to the instrument bezel, but no wires are connected. I want to go back to the ignition switch on the dash, not on the steering column. Here is a pic of the back of the switch, I see where the battery wire is connected, where the ground is connected, and where the ignition wire is connected, and the accessory wire connects to the switch. My question is what wire goes to the top most terminal, looks like "SOL" imprinted underneath the connector ?? |
03-19-2019, 07:03 PM | #2 |
Re: Ignition switch help please
That would be the solenoid terminal.
03-19-2019, 10:14 PM | #3 |
Yes. It is a purple wire goes to the Starter.
George |
04-08-2019, 06:05 PM | #4 | |
Does anyone know who sells or reproduces this connector ?? |
04-08-2019, 08:52 PM | #5 |
Surf through the ads in the for sale section. There are a few threads where folks are parting trucks.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-08-2019, 09:41 PM | #6 |
If you can't find a connector there's no reason why you can't use some insulated female spade terminals to connect the wires. Not pretty but perfectly safe and secure.
