03-17-2019, 05:36 PM | #51 |
Re: 3 spd shift linkages??
The 2-3 rod measures 22 1/4"
03-17-2019, 05:38 PM | #52 |
2nd pic.
03-17-2019, 07:53 PM | #53 | |
Posted via Mobile Device |
03-17-2019, 08:01 PM | #54 |
Special-k how long is this rod?
03-18-2019, 08:53 PM | #55 |
That’s definitely the 2-3 rod I have that fits
03-18-2019, 11:25 PM | #56 |
You're getting there!
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
03-19-2019, 08:47 PM | #57 |
03-19-2019, 09:57 PM | #58 | |
If it isn't, it's very close. You need to get a measurement on the circled one. That will give you a better chance of getting it right.
03-20-2019, 08:56 AM | #59 |
Here are all the measurements from left to right. I hooked the tape on the top end and measured to about center of mounting pin, meaning within 1/8"
23" - 22 3/8" - 24 3/4" - 22 1/4" - 26 1/4" - 28 7/8" - 27 1/2" - 29" - 30 5/8"
03-20-2019, 09:48 AM | #60 | |
03-21-2019, 01:14 PM | #61 |
Ok, the 5th one in from left... or right! I'll look into the cost
03-25-2019, 11:20 AM | #62 |
03-26-2019, 10:29 PM | #63 |
Pm sent
03-28-2019, 09:01 AM | #64 |
Hope your's works out. I got a set coming to me now. Good luck!!
03-28-2019, 11:15 AM | #65 |
03-30-2019, 08:40 AM | #66 |
Been busy this week. I posted all mine to help figure out this problem as well as to get them identified. I'm not a parts dealer, just a long time 67-72 GM Truck enthusiast who sells off some parts from my stash. Can anyone help me out with identifying, and help others in the future who pull this thread up? Clearly, it can get confusing when these rods are found off the truck and mixed up.
03-30-2019, 12:14 PM | #67 |
This is all of the ones I’m confident enough to label. I’ll confirm the 1/R rod for V8(in green) once I receive it and can try it. The other 4 rods not identified I feel are either 4 bolt side cover trans, or may have been distorted over 50 years.(I have 3 I have tried to reshape to make work with no success). No clue what that longest over 30” rod would be for.
03-31-2019, 12:28 AM | #68 |
I think the middle rod in the labeled picture(the one with the big curve), is like one of the ones NewBayColony got from Husker. Maybe he can report if it fit his 4bolt
03-31-2019, 08:59 AM | #69 |
I can give it a test fit when it gets here this week some time.
04-01-2019, 08:39 PM | #70 |
Special-K, Do you think you’ll be able to ship that rod out this week? Thanks
04-01-2019, 11:16 PM | #71 |
Old member
68 all original I just got Sat with 3 speed on the tree.
Hope these help. This truck was a 1 owner and as far as he could remember nothing had been changed on it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-02-2019, 09:17 PM | #72 |
It helps me as I see it's a 4 bolt side cover. Thanks!!
04-07-2019, 09:31 AM | #73 |
NewBayColony, did your linkages show up this week?
04-10-2019, 09:11 PM | #74 |
04-10-2019, 09:19 PM | #75 |
Sorry it took so long to do this. The shorter one is the 2/3 linkage. I don't have the transmission in yet, won't be for awhile but it sure does look like I have the correct ones. Big thanks to Husker Ron for digging these out and shipping them to me.
