Old 03-07-2019, 11:49 AM   #1
nikwho
nikwho's Avatar
Door seals help with my '59, please?
Hello all,
I ordered these new door seals from Summit Racing, since I was making a big order for a bunch of other stuff. I hadn't put much thought into them, until looking at what us currently on my truck. The seals are on the doors, and it's not glaringly obvious how they are to attach. I've read about some gluing on and some having clips. Any guidance would be greatly appreciated!
Thanks much,
Nik
Seals I purchased:
https://www.summitracing.com/parts/f...let/model/3100
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 03-07-2019, 11:59 AM   #2
slammed57
slammed57's Avatar
Re: Door seals help with my '59, please?
these are the ones you want from soffseal.
the glue on ones are kinda a pain in the butt.
https://www.summitracing.com/parts/s...make/chevrolet
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 03-07-2019, 12:09 PM   #3
nikwho
nikwho's Avatar
Like, so much of a pain in the butt that it's worth buying a new set? If the glue on ones are absolutely something to avoid, I will. If not, what kind of adhesive do guys use? I would have preferred to order from somewhere else, with the lack of information provided. My current seals must be glue on, as I dont have all of the holes in my door for those screw in seals, and honestly would prefer to not drill a ton of holes in my door. Thank you for your reply!
'68 GMC - BBC/TH400
Old 03-07-2019, 01:22 PM   #4
Daze57
Daze57's Avatar
i must agree with slammed 57----- glue on seals are 'ok' but really the clip type in my opinon
are much better --softseal is a good company ---i have the push pin set (same as clip in type)
most trucks i have seen and worked on have the holes for the seals ....i just think its a much better fit .
if you already have the glue on seals ---use black or yellow seal adhesive its great stuff but can get messy .
IMO....drilling holes in the doors (if needed ) isnt so bad as long as you measure between holes so seals fit snug --------my 2cents worth
Daze57 is offline   Reply With Quote
Old 03-07-2019, 01:33 PM   #5
_Ogre
_Ogre's Avatar
google: 3m weatherstrip adhesive
available at any parts store in yellow or black
make sure you understand the correct orientation of the weatherstrip
it goes on backwards to any logical thinking
chances are you have the holes, just covered in filler or newer metal
i'd glue it before drilling 100s of holes
shop air compressor timer
Old 03-07-2019, 01:47 PM   #6
nikwho
nikwho's Avatar
Thanks for all of the replies, guys. I'm dumb! I do have the holes. It's amazing how much I think that I remember, only to be wrong when I get my eyes on something. I bought a tube of the yellow adhesive. Im also ordering the push in/clip weather seals today. I'm in the middle of painting my '68, then this coming winter my '59 is going to get stripped down for new cab corners and paint. So, I'm gonna use just the drivers (missing) side glue in seal, to get me by until paint, then will go with the clip in seals once the truck gets painted.
_Ogre, heres how I imagined them going in. I'm sure that they need to flip, based on your comment!
'68 GMC - BBC/TH400
Old 03-07-2019, 01:52 PM   #7
nikwho
nikwho's Avatar
But, based on the only 90° angle on the seal, I could see them going in like this, too.
'68 GMC - BBC/TH400
Old 03-07-2019, 03:07 PM   #8
Rude Dude
Rude Dude's Avatar
There are a few you tube videos on correct install by various vendors for these doors
Rude Dude is offline   Reply With Quote
Old 03-07-2019, 03:13 PM   #9
nikwho
nikwho's Avatar
I found this video on ClassicParts' website. Linked to Youtube. It pretty much lays out the process.
https://www.classicparts.com/mobile/...ctinfo/03-011/
Nik
'68 GMC - BBC/TH400
Old 03-07-2019, 05:12 PM   #10
slammed57
slammed57's Avatar
spend the $28 if you can ......snap in and go! you'll be on the road in 30 min
My 57 current build
Old 03-10-2019, 07:20 PM   #11
Dan in Pasadena
Dan in Pasadena's Avatar
If they look like they're on right....they're not! The 90* angle does NOT conform to the door edge shape.
Also, let me put my two cents in for Steele Rubber Products. They cost a little more but I've never heard a single negative review of their products.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-12-2019, 04:06 AM   #12
Bigjas
This video might help you see how the clip in seals are installed
https://www.youtube.com/watch?v=pal2JnOsiV8&t=297s
I used this product and it fitted very well on my '57. They just clip in, really easy and no gluing.
Jas
Bigjas is offline   Reply With Quote
Old 03-15-2019, 11:22 AM   #13
Russell Ashley
Russell Ashley's Avatar
That is the correct orientation
Russell Ashley is offline   Reply With Quote
Old 03-15-2019, 04:16 PM   #14
my56chevytruck
my56chevytruck's Avatar
Mike is absolutely correct. You need the ones with the pins and from Soff Seal.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 03-16-2019, 01:16 AM   #15
nikwho
nikwho's Avatar
Thanks! Got the drivers side on without issue. Door is a little difficult to close now, but seems to have already gotten easier. I got the seal on okay, though I certainly wouldn't go out of my way to use these seals again. This truck is going to get taken apart for body work and paint before too long (once my '68 is finished in the body/paint shop), so I went ahead and used these since I already had them. Wasn't as bad as I thought that it was going to be. I am definitely going to order the clip in seals as suggested for when it goes back together after paint.
'68 GMC - BBC/TH400
