Old 03-18-2019, 02:55 PM   #1
Malone34
Milky oil advice
Finally got to work on my 72 yesterday she's been in the garage neglected for a year but trying to get it going. A little backstory I bought it and po had it sitting for about 6-7 years. Said it ran when it was parked but we've all probably heard that before. I pulled the valve covers and points distributor to put in a hei and noticed the oil on the distributor was milky. Checked the oil on the dipstick and looked normal. Was going to drain oil and pull the the oil pan off. Does anyone have any suggestions before I go any further. Still learning so take it easy on me. Forgot to mention it's a 327 from a 65 Vette per the numbers
1972 Cheyenne Super SB Stepside
Malone34 is offline   Reply With Quote
Old 03-18-2019, 03:50 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Milky oil advice
Just drain the oil and post a picture ,also what does the coolant look like ?
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 03-18-2019, 03:54 PM   #3
trac209
Could be just condensation frothed up on the gear mixed with oil. Give it an oil change,replace the coolant and start from there. A compression and or leak down test should give you an idea of the engines condition. If it hasn’t turned over in a while some oil sprayed into the cylinders will make sure it’s free of any stuck rings.
trac209 is offline   Reply With Quote
Old 03-18-2019, 04:01 PM   #4
Malone34
Didn't check yesterday but I'll check it out tonight.
Old 03-18-2019, 04:03 PM   #5
Malone34
Thanks. So is removing the oil pan not really necessary?
Old 03-18-2019, 04:20 PM   #6
rockyrivermark
Removing the pan isn't necessary.
As stated. Change oil and antifreeze and go from there.
Then keep and eye on what the oil looks like and the level of both that and coolant.
If coolant getting in oil level should go up.
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 03-18-2019, 04:32 PM   #7
Malone34
Mark
Old 03-18-2019, 05:32 PM   #8
rjs53
If the coolant has oil in it you know you got problems. If its just in the oil it might be a blown head gasket. Easy fix.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 03-18-2019, 06:07 PM   #9
rockyrivermark
Yep. Mine was a leak in an intake gasket.
But head gasket is usually the first culprit
My build page
Old 03-18-2019, 07:56 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'd recommend using plain water for coolant until you are convinced that the water in the oil is just condensation.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 03-19-2019, 08:50 AM   #11
sick472
sick472's Avatar
I would consider running the engine for a short period to get it up to running temps before changing the oil so that the existing moisture gets flushed around and emulsified into the old oil. Then change it. Otherwise, water will likely show back up in the fresh oil and leave you wondering.
Watch the temps as it warms up and make sure it does not want to overheat.
Look for burping in the radiator (usually shows up burping out of the overflow line)...a head gasket leak (or head/block crack) could produce compression gasses that escape into the cooling system.
Check spark plugs for coolant fouling. A head gasket leak/crack that goes the other way can allow coolant into the cylinders causing the spark plugs to have build up on them. Make note of where any suspect plugs came from, just in case, so you know which head to pull first for inspection.
Watch/smell the exhaust for coolant fumes. Dual exhaust can also help identify the suspect side. If the coolant is still fresh looking, I would leave it in the system as coolant has a distinct smell if it ends up coming out the exhaust.
As mentioned, a compression test can tell a lot. Typically, when a gasket leak or crack is suspected, poor compression in a cylinder is a good indicator that the problem lies within that head/cylinder.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 03-19-2019, 02:32 PM   #12
Malone34
Thank you all for your comments that's why I love this site. Sick472 thanks for all the information you gave. Like I said before I'm still learning so the extra info helps out. Hopefully getting this going by the weekend. Work schedule and a 2 year old dictate alot of my time haha. Thanks again for everyone's input
Old 03-20-2019, 12:32 PM   #13
sick472
sick472's Avatar
No worries..glad to try and help!
I would like to add that a few of my motors have shown "milky oil" under the oil cap, pcv, and valve covers due to weather conditions. Basically, condensation gets in the motor and seems to settle high in the engine. This does NOT make the oil in the pan milky. I can not explain it, but it happens a lot in the winter time around here. If this is the case...it's nothing to worry about and should go away on it's own under normal use, but may return under the correct weather temps and humidity levels. Hopefully this is your situation, but still check it all out.
1972 C10
1985 K20
Old 03-20-2019, 02:08 PM   #14
Malone34
Yeah considering this is where I saved her from I'm hoping that too. Worst case it would force me to start the ls conversion a couple years sooner than I anticipated haha
Old 03-20-2019, 02:12 PM   #15
Malone34
Didn't upload first try
Old 03-20-2019, 09:57 PM   #16
El Dorado Jim
nice truck, looks like the 72 I had in high school
El Dorado Jim is offline   Reply With Quote
