Old 06-17-2018, 08:29 AM   #1
72LB
72LB's Avatar
Reverse light question
My 69 now has a lokar floor shifter and I'm going to rebuild a manual column using a shift delete collar from a dump truck. My question is how to go about getting the reverse lights to work?
My thought is to just wire a switch somewhere since the lokar shifter doesn't have a spot for one just the neutral safety. I know some have gone a floor shifter, any ideas would be appreciated.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 06-17-2018, 10:01 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Reverse light question
Depending on the shifter you have is the N safety switch on top of the trans in the shifter or mounted to the pan with a bracket ?
https://www.speedwaymotors.com/Lokar...Kit,43362.html
Grumpy old man is offline   Reply With Quote
Old 06-17-2018, 01:09 PM   #3
72LB
72LB's Avatar
Now that I didn't know lokar had and I looked thru their online catalog. My neutral safety switch is on the side of the shifter.
