Old 12-15-2012, 12:58 PM   #1
cjohnson6772
cjohnson6772's Avatar
to anyone running a truck ac bracket
I have notched my compressor bracket with no issies, but how do you connect the red plug?!?!?!?
cjohnson6772 is offline   Reply With Quote
Old 12-15-2012, 08:23 PM   #2
clinebarger
Re: to anyone running a truck ac bracket
Thats the High Pressure cut-out switch, Not used on swaps.
You can run a Trinary on the a High side line..... http://www.oldairproducts.com/catalo...ch-p-2754.html
Use a Relay for the fan, The diagram doesnt show one but is necessary.
The Trinary switch is a 3 function switch. It Protects the system from excessive high or low system pressures plus it will automatically operate electric radiator or condenser fans as needed for maximum sytem performance.
Trinary Safety Switch Pressures:
LOW is OFF @ 28PSIG - ON @ 29PSIG
HIGH is OFF @ 454PSIG - ON @ 369PSIG
FAN - is ON @ 227PSIG - OFF @ 185 PSIG
clinebarger is offline   Reply With Quote
Old 12-15-2012, 08:31 PM   #3
cjohnson6772
Awesome! That means my A/C bracket should work with the notch I'm pretty sure the switch in my current A/C set up (manual fan/TPI/Sanden 508) is a binary switch. So with a trinary switch, will the PCM still control the compressor and fans? If I understand your post correctly, with PCM controlled F-Body fans and PCM controlled compressor the fans would run when the PCM deemed necessary due to the coolant temp OR when the trinary switch deemed necessary for better A/C performance. Is that correct?
Old 04-24-2013, 11:58 PM   #4
cjohnson6772
Bump for clarification please. Also: I have my binary switch installed right after the bottom of the condenser. Is this location ok?
Old 04-25-2013, 08:07 AM   #5
1970 C10 MJW
1970 C10 MJW's Avatar
i dont know much about this, but I would like to know exactly how that work, sense I plan on doing A/C at some point
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 04-25-2013, 08:18 AM   #6
Clyde65
Clyde65's Avatar
I have old air on my truck with the LS swap. Clinebarger did my AC stuff for me, since I havent a clue. My Trinary switch is right at the condenser, I dont think it matters as ling as it is on the high side, however, when I installed my Old Air kit, they said put it near the condenser. PM Clinebarger if you have further ?'s
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-25-2013, 09:36 AM   #7
faribran
thanks guys, this is very helpful info...
faribran is offline   Reply With Quote
Old 04-25-2013, 11:47 AM   #8
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Im not Clinebarger, but I will try to help...
yes
In your current setup if the PCM is controlling the fans for coolant and you add this switch then either or both will cycle the fans. The PCM will only turn on and off with coolant temp and the trinary will cycle on and off as necessary for the AC based on the pressures previously posted. Just make sure you are tapping the trinary into the correct relay circuit for the cooling fan (should already be there if the PCM is controlling the fans)
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 04-25-2013, 06:05 PM   #9
cjohnson6772
yes
Thanks for the info. Is a trinary switch worth the extra money and effort if I have a binary switch already? I don't think I understand why the fans need to turn based on the compressor pressure...I mean they are already temp controlled? What is the added benefit of a trinary switch in this scenario? Sorry if this is a dense question :\
Old 04-25-2013, 06:34 PM   #10
Daaaanz67
This is good info getting ready to do a/c also. Can someone post a wiring schematic for the trinary to the fan that's already controlled by PCM. Maybe Cline can chime back in on this thanks.
Daaaanz67 is offline   Reply With Quote
Old 04-25-2013, 08:15 PM   #11
clinebarger
Without a mechanical fan it's Mandatory in my opinion! At low speeds/stopped you will need airflow across the condenser if Head Pressure gets to high (<250 psi)....High Head pressure will.....Decrease A/C performance, Blow lines, Break belts, Break the compressor, Break the tensioner & Smoke compressor clutches.
Do Not wire the Trinary to the PCM controlled relays, It will set codes & the PCM will freak out & turn the fans on at all times....Here's a diagram on the Correct way to wire it....
Old 04-25-2013, 10:26 PM   #12
cjohnson6772
It t was then that he realized that the condenser also needs airflow and not just the radiator.....doh
So to add to the diagram: pin 87 of the pcm relay and pin 87 of the trinary switch relay will both be hooked to the hot wire on the fan?
In the interest of pursuing alternatives: could I not just wire my a/c signal on wire (clutch hot wire) to pin 86 of the additional fan relay and forgo a trinary. I believe this would turn the fans on any time the clutch was on.
Since the PCM gets a A/C power signal and controls the clutch....could the fans not be programmed to turn on with the clutch with no additional mods?
Thanks for all the advise and patience. I'm just trying to fully understand my options.
Old 04-26-2013, 01:21 AM   #13
chevyman70
I have a mechanical fan on my swap. Will that be sufficient to cool condensor and keeping the engine cool?
chevyman70 is offline   Reply With Quote
Old 04-26-2013, 07:21 PM   #14
clinebarger
You can wire it to run anytime the A/C is on, But the fan Does Not need to run a highway speeds & will wear the fan motor out prematurely.
If your running a 134a parallel flow condenser, And the shroud fits correctly around the fan....Yes, It should be fine.
If you got a R-12 "tube & fin" condenser or the shroud doesn't fit the fan right.....Your going to have problems.
As a matter of fact I run a Mechanical fan on my Burb.
Old 04-26-2013, 09:18 PM   #15
chevyman70
The condenser I ordered is a parallel flow, and my fan fits like a glove on my shroud, tight fit. So, Ill try it with the mechanical first, if I have cooling issues, then i'll change over to a pair of electric fans. Thanks for the tip!
Old 04-26-2013, 09:24 PM   #16
cjohnson6772
Looks like a trinary switch is gonna have to fit the bill. I just hated the thoughts of adding wires and relays if there was any chance I could just let the PCM logic handle it :\ I guess you shoulda told me like my dad always did "You have two options: you can do it my way now or you can try it your way and then do it mine later"
As an aside: Will this compressor block work on my compressor? The links all say R4/A6 rear mount and the pad face looks to be perfectly flat. My compressor is off a 2001 LQ4 and I thought the original pad face would have a slight offset. Thanks again everyone.
Old 04-26-2013, 11:14 PM   #17
clinebarger
You could have a HU6 Harrison/Delphi compressor or a 10S17F Denso compressor???
Old 04-26-2013, 11:17 PM   #18
cjohnson6772
I've been researched since I've posted and it is definitely the Delphi HU6. Will the above fitting work? My concern is that the fitting looks like it has a perfectly flat mounting pad and I thought the compressor was slightly stepped.
Also: Clinebarger your knowledge never ceases to amaze me. You have to do some of this stuff for a living...
Old 04-27-2013, 12:52 AM   #19
clinebarger
The pic you posted shows the sealing surface steps down a little??
That manifold may fit your HU6, The O-rings will not work....You will need sealing washers...You can even use thicker sealing washers & pilot extensions to step the sealing surface down if needed....http://www.sosmetalproducts.com/cata...s/l/171618.pdf I have the 65 piece kit.
Color codes...http://www.4s.com/Upload/Four%20Seas...%20SEASONS.PDF
Yes, I do this for a living, Air conditioning & Automatic transmissions have the highest profit margins IF you know what your doing
Old 04-27-2013, 10:39 AM   #20
cjohnson6772
This almost makes me think what I have might work: the first pic is what came off the compressor. The second is off a junkyard s10 blazer. I can bend the blazer line and tig threads to them if the sealing surface will work! The step down on the blazer pad concerned me though.
Old 06-10-2013, 12:02 AM   #21
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Subscribed. But I'm not running electric fans. I am using the stock 6.0 fan with the stock 72 GMC fan shroud.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 06-14-2013, 08:38 PM   #22
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Great thread! Subscribed.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 07-30-2013, 07:05 PM   #23
cjohnson6772
Just came back from getting my compressor charged and I've got an issue. I've got my compressor clutch wired in with the trinary switch inline, but I'm not getting a signal on either side of the trinary switch. I've check and the A/C relay is not getting grounded by the PCM on pin C2-43. I suspect the culprit is the missing high pressure sensor supposed to be on pins C2-14, C2-57, & C1-45. I have a plug in my harness for the sensor, but there is no way to hook it up because of my engine stands. Is there a way to "tune this out" or "sppof" the PCM into ignoring the sensor? It doesn't look like a switch that I could just bypass of a potentiometer that I could just use resistors to get around, so I'm lost. As always thanks in advance for the help.
Old 07-30-2013, 09:00 PM   #24
Clyde65
Clyde65's Avatar
Clinebarger did my rewire and Ac repair, what a mess I had. Now my truck rolls down the road with Ac on or off at 190 degrees in our lovely Texas heat. He knows what he is talking about, he does these swaps everyday.
Clyde65
Rebuild of Clyde
support our troops!
Old 07-30-2013, 10:52 PM   #25
clinebarger
The original switch on the compressor was not a pressure sensor, It was a Cut-Out switch....Pressure too high would interrupt the A/C request signal. 99-02 trucks are all wired this way because of the mechanical cooling fan.
Cars (4th gen F-bodies) do have a pressure sensor mounted on the Liquid Line. Using this the PCM was able to control head pressure with the cooling fans.
I'm guessing your running an F-body OS/segment swap to run electric fans. This will prevent ECM controlled compressor operation if no pressure reading. Also....If the harness is early truck....There is not a 3-pin pressure sensor plug, Only a 2-pin high pressure cut-out switch plug.
This is my opinion.....Run the compressor control wire straight to the aftermarket Trinary then to the compressor & bypass the ECM all together.
