Old 10-22-2020, 08:22 PM   #1
Nima
Blue 67
4L60E rebuild, no 3rd gear
Hi There:
For the first time I rebuilt a 4l60e (2001 suburban 1500 4X4) which had failed 3,4 gears. I watched a lot of videos and I followed transmission bench rebuild videos mainly for the rebuild. I was very confident that I followed the instruction to the point. I replaced the sun gear as well the shift solenoids.
Long story short, I took the the truck for a less than a mile test drive on our private road, I didn't notice if it shifted to the 3rd or no since I was going slow and trying to listen for any explosion! when I got back, I noticed the huge transmission fluid puddle under the truck. The cooler return line has popped out and tranny was drained. There was this slight hot/burning smell. I popped the line back in (double and triple checked it again), filled the tranny again, went through all the gears few times while stationary and took it for another test drive. It does not shift to 3rd. It doesn't even try. Did I burn the 3rd and 4th? Is there anything else I can check? does less than few minutes will ruin the clutches?
Thanks for the help.
I guess I have to add this: there was a lot of fluid leaked on the exhaust pipes and I am hoping the burned smell was from that.
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 10-22-2020, 08:49 PM   #2
truckdude239
truckdude239's Avatar
Re: 4L60E rebuild, no 3rd gear
sound like u riped one of the orings on the back pf the pump stator going in and you have no fuilded going to 3rd
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-22-2020, 10:11 PM   #3
Nima
Blue 67
Okay, that still means I have pull everything apart
I was hoping I don't have to do that.
Old 10-24-2020, 06:20 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
No 3rd or 4th....
Bad sprag unit
or
Burned up 3/4 clutch pack
or
BOTH !
Did you have the convertor replaced or flushed during the build?
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 10-24-2020, 07:36 PM   #5
Nima
Blue 67
I did flush the converter. Basically I flipped it and let it drain over night.
Old 10-25-2020, 06:08 PM   #6
AussieinNC
Moderator
AussieinNC's Avatar
Convertors are a haven for all types of contamination when a trans dies....
Flipping it and letting it drain will do zero to remove these contaminants....
The lockup clutch face surface cannot be checked for damage....
The internal components cannot be checked for damage...
The contamination residue including metal dust and clutch dust cannot be removed...
The burnt oil on the ground would most likely be a direct oil dump from the convertor....
Sorry to say this but IMHO...pull the trans, send the convertor out to be split and overhauled...do not accept having it flushed...
Then pull the trans back down..It will need to be fully dismantled and everything cleaned up, resealed and reassembled...
Change the sprag out to a BW late style...
As a heads up, there are several write ups on our forums especially detailed ones by "clinebarger"...who in my mind is the best trans guy I have ever seen....he does it right first time for a reason...its the right thing to do...
Hope this hasnt been to harsh a response....there is no easy fix for this...
2012 Chevy Equinox
Old 10-25-2020, 10:47 PM   #7
clinebarger
When the 3-4 Clutches are smoked.....But you still have 3rd Clutch apply circuit integrity......
*3rd clutch apply oil knocks the 2-4 Band off via the 3rd clutch accumulator behind the 2nd apply piston.
*With no 3-4 clutch holding ability.....The trans will now be in 1st gear causing a big Flare.
If it just stays in 2nd gear.....That could be a 3rd Clutch apply circuit integrity issue, Like a big leak.
clinebarger is offline   Reply With Quote
Old 10-26-2020, 12:47 AM   #8
Nima
Blue 67
Not at all. I appreciate the info.
Old 10-26-2020, 08:14 AM   #9
AussieinNC
Moderator
AussieinNC's Avatar
Absolutely CORRECT !!!!
2012 Chevy Equinox
Old 11-08-2020, 09:43 PM   #10
Nima
Blue 67
Okay, I pulled the transmission again and took it apart and looked for any broken seal or other things. I took the input drum and put it back together with new sprag although the old one still looked okay to me. Since the all other parts were new including the pistons, I test fit them for being snug when put together, I put everything together. When I pressure test the input drum using air compressor setting at 40 PSI, I get a leak which comes from the hole the center of input shaft inside the drum (there are 4 holes, 3 seems to have a ball in them and one without it) when I test 3-4 clutch (the hole closer to drum, at the same time I am blocking the release hole on the side). The forward clutch and over run clutches seals very well.
I thought I may have damaged the pistons when I installed them. I took the drum apart and installed new set on pistons. The same result
Is the drum bad? I don't see any visual defects.
I appreciate any help.
Old 11-09-2020, 12:00 AM   #11
clinebarger
The open hole at the end of the Input/Turbine Shaft is the Lube Feed hole that feeds the Output Shaft than onto the Geartrian.
There shouldn't be any cross leaks between it & the 3-4 Piston feed hole.
Lube is fed from the cooler return through the pump, Then through the stator support, Then through the hole in the picture. Then travels through the Input Shaft to the open hole at the end.
Old 11-09-2020, 12:21 AM   #12
clinebarger
If it in fact has a cross leak between the lube circuit & the 3-4 circuit....I'd almost have to be the Input Shaft.
I have never ran across this before & I'm assuming you're air checking the drum by itself?
Old 11-09-2020, 01:04 AM   #13
Nima
Blue 67
I am very new at this and in fact, this is my first automatic rebuild. So, what I have done is based on my reading and online videos.
When I pressure check, I put my air gun nozzle in that hole in the picture, I block the hole on the drum's body with my finger and based on what I have researched, the 3-4 clutch should hold the pressure with no leak, but I get the leak from the drum and when I hold my hand over the input shaft inside the drum, I feel the air.
I am sorry but I don't know the exact science (the flow) of the system. So, I need a new drum or is it possible that I am installing something the wrong way?! It seems very straight forward process in the videos!
Old 11-09-2020, 02:36 AM   #14
clinebarger
The 3rd apply circuit could be leaking around the splines of the Input Drum-Input Shaft interface giving the false sense that it's leaking out the lube hole.
Old 11-09-2020, 10:04 AM   #15
Nima
Blue 67
What would be the cause of that? And, can it be fixed?
Old 11-10-2020, 12:02 AM   #16
clinebarger
A new or good used Input Drum would be the fix, The cause is either fatigue or a crack in the drum.
You can lightly smack the drum with a 3/8" extension & it will Ring very clearly like a bell if it's not cracked.
Old 11-10-2020, 07:21 PM   #17
Bigdav160
Bigdav160's Avatar
You didn't forget the green o-ring in the bottom of the input drum did you?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-11-2020, 12:49 AM   #18
Nima
Blue 67
No, I did not forget. I guess that would make it easier.
Old 11-24-2020, 11:09 AM   #19
Nima
Blue 67
Okay,
I took the tranny off and remove the input drum. I got a different input drum (used but tested one, whatever that means, with all new seals already installed), disassembled and reassembled the new drum with new sprag, tested and this time there was no air leak on any of the clutch packs when I use 40psi air pressure. I did not touch anything else in tanny since I though there is no need for it.
Pu things back together and put the tranny in the truck with fresh fluid, no 3rd!!!
This time, it is shifting hard from 1st to second while before, the shift from 1st to 2nd was very smooth.
This seemed very clear process but now it feels so confusing! What am I missing?
Is there an illustrated reference book for 4L60e? Could it be wiring, that I am connecting the wires wrong on transfer case? But the transfer case is not suppose to be engaged in 2wd mode??!!
Old 11-25-2020, 09:28 AM   #20
Bigdav160
Bigdav160's Avatar
Two different occasions I had 4L60e brought to me that had been "rebuilt" but didn't shift (no codes). In both cases the shift solenoids were not fully inserted and the retaining clips were in the o-ring groove.
No grooving inside the stator support?
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
