06-27-2020, 05:42 PM | #1 |
What chassis do I have?
I have a 1965 GMC 3/4 ton truck...that's what the VIN number tells me anyway...
At some point in its lifetime, someone did a 5 lug swap and drivetrain swap; it has leaf-springs in the rear. I believe everything that was swapped was from a 1975 C10 (based on casting numbers and the PO's story). I plan on lowering the rear-end a few inches. I don't want to buy parts and see if they fit only to find out that they are wrong. My question is this; is there a difference between a 1965 chassis and a 1975 chassis...and if so, how can I tell which one mine is?
-Tim '65 GMC that identifies as a Chevrolet |
06-27-2020, 05:57 PM | #2 |
Re: What chassis do I have?
Are you asking about the frame?...I would suspect a big difference In the frames..are cab and body mounts stock looking or homemade looking?...is the rear soa or aos?...if aos ,then a simple drop block and ubolts would do it
06-27-2020, 06:01 PM | #3 | |
It is soa, so I can't do blocks and U-bolts. I've been searching for a bit and haven't been able to find any definitive way to tell them apart...I'm hoping someone on here has the answer!
06-27-2020, 06:20 PM | #4 |
If all the body mounts look stock to the frame, then most likely they did a drivetrain swap...can you get pics of the drivetrain parts and mounts?
06-27-2020, 06:54 PM | #5 |
It looks factory to me for the most part.
More photos: Driver side body mounts: The bracket is riveted and looks stock...but why are there two sets of holes? Leaf-spring mount: Rear-end: Welded-on shock mount:
06-27-2020, 07:03 PM | #6 |
I had big plans for this truck this year but unfortunately I got laid off about 3 weeks ago. I am going to have to hit the pause button for a while on the "big" stuff.
06-27-2020, 07:37 PM | #7 |
Most GMCs came with leaf springs in the rear from the factory. Do the front frame horns match the contour of the bumper?
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-27-2020, 09:45 PM | #8 |
From what I can see it looks like your on a stock frame,,, but the rear axle has been swapped...
For a quick easy/cheap drop in the rear , you could pull a couple of leaves outta the spring pack.. It will affect ride and hauling, but if those are stock 3/4t springs it may not matter much.... Drop springs would be the ideal way to do it though....
06-27-2020, 10:58 PM | #9 |
60-66 Nut
That is your original frame with a 12 bolt swap likely from the '75 donor. GMC's came standard with leaf springs.
06-27-2020, 11:26 PM | #10 | |||
You guys rock!
06-28-2020, 12:41 AM | #11 |
How much clearance do you have between the spring eye and the bed floor? It looks fairly close in your pic..
A drop shackle may also change your pinion angle some...
06-28-2020, 01:27 PM | #12 | |
I will probably just buy the leaf springs either way.
06-28-2020, 08:52 PM | #13 |
Hey I got 65 gmc swb used 76 rear axle used flip kit for 73-87 still using original springs replaced bushings and hangers tried to upload a picture but would not load send me a pm if you want info on bushings and hangers
