Old 06-23-2009, 09:25 PM   #1
bigbadjohn84
89 Chevy rear end width
Does anyone know if the 10 or 12 bolt rearends under the 73-87 chevy trucks are narrower or are the mounting pads just differenet? I am looking for a rearend for my 89, that would be around 2 in narrower, so that I can pull my 295/50 R15 deeper into the fender wells so when I drop it on down there won't be clearnce issues.. just want to avoid floppin down a grand or two just for shortening my factory housing and axles.. or would something like a ford explorer rear work? I am going to wind up loading the housing with Detroit True Trac and 4.11.. to wake up my 383 tbi I have built. but I want it LOW lol
bigbadjohn84 is offline   Reply With Quote
Old 06-23-2009, 09:55 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: 89 Chevy rear end width
You want it low, huh? How much lower in Alabama can you get and not be in Florida. I went thru your town, once.
If you don't get an answer pretty soon, I can move this to the engine/drivetrain forum. There's some knowledgeable folks over there, too. Only thing is, they're oriented toward drivetrains.
Member Nr. 2770
Old 06-24-2009, 11:44 AM   #3
bigbadjohn84
yea man.. like 8-9 inch of drop over the rear and tuck those fat tires. thats the look I want. sorta a pro street look. loud, wide, and nasty. yea thats me, smallville Alabama lol. how do you move the post? that would be helpful
Old 06-24-2009, 11:00 PM   #4
Captainfab
60-66 Nut
The '73-'87's are a couple of inches narrower than the '88 and up differentials. I have the exact measurements at the shop. I can look it up tomorrow and let you know.
Old 06-25-2009, 11:19 AM   #5
bigbadjohn84
sweet!! thanks! I was wondering that. I knew some of the 73-87 I have had tucked 10 in wheels in the back with no issue. I just wanted to be able to tuck my 8 in wheels
Old 06-26-2009, 11:57 AM   #6
bigbadjohn84
I measured my rearends. I have a 81 C10 2wd and a 89 C1500 2wd. the inside width, measured between the insides of the brake drums appears about a inch narrower on the c10. has anyone changed the rear out of an 89 in favor of the 12 bolt C10? I need it a little narrower so I can squeeze those 295/50 R15 up in the rear fender well.. any help would be appretiated
Old 06-26-2009, 10:57 PM   #7
Captainfab
60-66 Nut
Just a little FYI.....that's not the correct way to measure a differential. You need to measure the wheel mounting sufrace to wheel mounting surface (WMS) This is where it matters.
The 10 bolt in my '90 C1500 measures 64 3/4" WMS to WMS
The 12 bolts in the '70-'80 C10's measure 63 1/2" WMS to WMS
The 12 bolts in the '63-'70 C10's (6 lug)measure 62 1/8" WMS to WMS
The '81-'87 10 bolts should be the same width as the '70-'80 12 bolts, but I haven't measures one to verify that. So there is a little info for you to work with to see what will work for your truck.
Old 06-27-2009, 02:50 AM   #8
bigbadjohn84
hmm.. I have a 70 out in my pile of stuff.. but I guess I would have to get 5 lug axles beings its 6 lug. that sounds like it would be just right to tuck those tires like I want too. I'd have to change mount and all too.. but that's no biggie. I plan on flipping it to the top of the leafs anyways to make my drop. that would eliminate the need to purchase a flip "kit". just relocate my factory mount pads.. anyone done this? does it seem worth it? If I could find a custom offset wheel all this could be avoided. thats my whole issue. I am running a 15x8.5 wheel. I don't know what the backspacing is. it's a Ultra brand wheel, polished aluminum. looks like a rip off of the old Cragar Street star. I just love the look of those 295/50 under the back.. plus with my little stroker I built I need the meats along with a locker lol
Old 08-31-2018, 03:28 PM   #9
Handsome65
Hi,
I have a 65 C20, and was thinking about swapping the Eaton semi floater out in favor of a Full Floater from a 2013 Chevy Duramax Silverado. I know the rear track of my Eaton, but not so sure about the 2013 full floater, and cant seem to find it on the internet. Does anyone know, by chance?
Handsome65 is offline   Reply With Quote
Old 08-31-2018, 07:00 PM   #10
b454rat
9 year old thread, nice. It's wider, like 69".
Old 08-31-2018, 07:29 PM   #11
Handsome65
yes, I know it's an old thread, but it seems to be relevant to my question so I figured it was as good of a place to post as any. That said, the rear track of my 65 C20 is 67 in, so if the other axle is 69, that's pretty close, I think. Anyone disagree?⅝
Old 01-28-2021, 11:29 PM   #12
Jaybob
I know this is an old thread but I am interested in this topic. Have been looking and measuring and I swear the the 73-80 12 bolt is narrower than the 81-87 10 bolt. As far as I can tell the 73-80 12 bolt is 63.5" axle to axle or 63.75" WMS to WMS. The 81-87 seems like it is a little wider at 64.25" axle to axle or 64.5" WMS to WMS. I have measure my 78, but I don't have a square eye square body to compare to. I am building my own 15x11 rally wheels and fitment and backspacing choice is crucial. It looks to me that you would need different offset as they are different by 3/8" per side.
Anyone else have verified 81-87 2wd 10 bolt rear axle widths?
Jaybob is offline   Reply With Quote
