01-30-2021, 04:22 PM | #1 |
4wd Enthusiast
Help with big block id stamp
I am trying to decipher the id stamp on the BB in my 72 k20. It is pretty worn down and hard to read. I am unable to get to the back of the block to find the casting numbers for it. Was told it is a 454 installed in the mid-80's. Maybe imaging software can clean it up? Looks like TI017CGU? Looks to translate to a 1970 Impala/Caprice LS-5 390hp block made 10/17? Wouldn't that be cool...There is another unreadable stamp on the back part of the pad with a smaller font. Any help would be appreciated.
Looking to get correct short ram horn exhaust manifolds for the engine. I want to make sure I get the correct year.
*1972 Cheyenne Super SWB K10 Original Paint 350/350 AC (Added) Tach/Tilt *1972 Cheyenne Super SWB K10-Buckets/Tach/Tilt/Wood Bed/Manual Throttle/Marker Lamps *1972 Cheyenne Super Custom Camper K20 AC/Tilt/Aux Tank/Aux Battery/Wood Bed *1970 Olds 442 W-30 M-21 4-speed *1978 Ford F250 4x4 Ranger-Explorer-Camper Special Marti Report: 1 of 1 *1986 K30 Silverado Crew Cab 502/TH400 *2002 Silverado LT 2500 Duramax Long bed Crew Cab 4x4 107K original miles *2022 RAM Bighorn 1500 Waldoch edition ...Daily Driver Last edited by pryorstemmed; 02-04-2021 at 05:48 AM. |
01-30-2021, 05:55 PM | #2 |
Re: Help with big block id stamp
well 454 has external balance flywheel and dampener so thats a super fast check . it the dampener has a extra notch on it cut out or added then its a 454 . otherwise its a 396 to 427 bbc .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
01-30-2021, 06:07 PM | #3 |
4wd Enthusiast
Yup, it's a 454. Trying to find the year to get the correct shorty rams head exhaust manifolds. The original owner put on long tube headers and they are rubbing against the front drive shaft. Thanks for the reply!
*1972 Cheyenne Super SWB K10 Original Paint 350/350 AC (Added) Tach/Tilt *1972 Cheyenne Super SWB K10-Buckets/Tach/Tilt/Wood Bed/Manual Throttle/Marker Lamps *1972 Cheyenne Super Custom Camper K20 AC/Tilt/Aux Tank/Aux Battery/Wood Bed *1970 Olds 442 W-30 M-21 4-speed *1978 Ford F250 4x4 Ranger-Explorer-Camper Special Marti Report: 1 of 1 *1986 K30 Silverado Crew Cab 502/TH400 *2002 Silverado LT 2500 Duramax Long bed Crew Cab 4x4 107K original miles *2022 RAM Bighorn 1500 Waldoch edition ...Daily Driver |
01-30-2021, 10:36 PM | #4 |
60-66 Nut
Why do you need the exact year to be able to get exhaust manifolds? It is a Mark IV big block. All MK IV BBC manifolds will work. The chassis fitment is more important than the exact year of the engine.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-30-2021 at 10:41 PM. |
01-30-2021, 10:44 PM | #5 |
4wd Enthusiast
Not that educated on big blocks so i wanted the year to know the block series. Thank you.
01-31-2021, 01:28 AM | #6 |
Unless you're spinning that big block past 5k all the time stick with the iron manifolds and save years of headaches
01-31-2021, 02:25 AM | #7 |
4wd Enthusiast
That is the plan. The truck will be a grocery getter and weekend trip rig. Thanks!
