02-17-2011, 11:45 PM | #1 |
Simple? What's simple?
home-grown light upgrade
Always looking to upgrade lighting on my truck - this is an upgrade I first did on a buddies' '67 mustang coupe.
Jeep JK Wrangler headlights ('07-current) are a direct bolt in swap for the old sealed beam headlights in our trucks. Requires changing from the H4 style connector to a H13 style connector (late model fords, jeep, etc). This whole swap (using junkyard parts) cost me about $100, including silverstar bulbs. one old, one new new on right (crisp light cutoff and concentrated beam), old on left (wider, more scattered light and hazy cutoff) Lows, silverstar bulbs and new housings Highs difference in the amount of light on the road ahead of you is absolutely night and day. Well worth the hour and a half of effort.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
02-17-2011, 11:49 PM | #2 |
Re: home-grown light upgrade
Did you upgrade the headlight wiring harness to use relays?
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
02-18-2011, 12:25 AM | #3 |
its all about the +6 inches
THIS is the kind of info I love seeing on here.
If you haven't done the relay mod yet, do it. Your lights will be just as bright as when they were on the Jeep. Also... silverstars are amazing bulbs for those not in the know |
02-18-2011, 12:28 AM | #4 |
No relays yet, it's in the works - need to modify the plow lights harness to better fit the truck, will add them at the same time
02-18-2011, 12:58 AM | #5 |
Very cool, can someone elaborate on the relay upgrade?
Posted via Mobile Device |
02-18-2011, 01:11 AM | #6 | |
you take 2 standard normally off relays, and hook them into the high and low beam power wires on the headlight harness on one side, and to the battery/alternator on the other. Then you use your original high and low beam wires to trigger the relays and supply power to the headlights right from the battery (or alternator). This serves two purposes: 1. it gives your headlights the most direct line of power they can have, allowing them to perform to their fullest potential and 2. it prevents your new, upgraded headlights from pulling too much current through the 40+ year old headlight switch and causing it to fail (or light on fire )
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) Last edited by JJorgensen52; 02-18-2011 at 01:12 AM. |
02-18-2011, 01:27 AM | #7 |
Great mod!
Too bad they're plastic or I'd do it in a heartbeat. Southwestern sandstorms and UV rays are not conducive to their longevity |
02-19-2011, 02:46 AM | #8 | |
'69 Chevy SWB
very cool. I'll be looking into doing this
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
02-19-2011, 10:54 AM | #9 |
Should this mod work on the 67-72 gmc's also?
02-19-2011, 11:17 AM | #10 |
Old member
Can you show the upgraded connector you speak of. I would like to see the diferance between the two. I have done the light update with aftermarket lights with the relays just was thinking about the bulb upgrade.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-19-2011, 01:09 PM | #11 |
Junior Member
Here you go.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
02-19-2011, 01:13 PM | #12 |
great info.
Doug Looking for a 67-72 short bed driver..... |
02-19-2011, 01:29 PM | #13 |
Sooo....where can you buy the relay? this sounds like a great easy upgrade that i would like to do. Is it a over the counter part? can i swipe it from the jeep when i find my headlights?
1969 Chevy K20 Longbed |
02-19-2011, 01:54 PM | #14 |
Autozone carries the 4lug relay and a 5 lug relay for less than 5.99ea.
02-19-2011, 02:04 PM | #15 |
very cool upgrade, thanks for sharing... pics of the entire process would help some of the guys...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-19-2011, 02:05 PM | #16 |
heres a ebay listing for the 7" round conversion kit-
7" round Conversion |
02-19-2011, 02:20 PM | #17 |
Too many projects
I'll be saving this page so I can do my k20 and my nova.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
02-19-2011, 02:33 PM | #18 |
English Chevy Owner
LMC sell a ready made conversion harness with the relays etc, just plug it in. Top of the page, tbh by the time you've bought the relays, cable and connectors it won't be much cheaper and this is very neat. http://www.lmctruck.com/icatalog/cb/full.aspx?Page=69
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
02-19-2011, 09:02 PM | #19 | ||
Also, for those who have state safety inspections, the aftermarket lights are not actually legal (and I have been gigged for it). The Jeep headlights are SAE and DOT approved for road use. These are the connectors that the new headlights use. http://www.repairconnector.com/produ...or-Socket.html Quote:
That said, I can tell you the following: On the factory bulb, when you pull the connector off the back and look at the socket, you'll see three slots, two vertical on each side and one horizontal on top. The driver's side vertical is ground, the top is low beam and the passenger's side vertical is high beam. On the new connectors, black is ground, red is low and green is high. (I always test just by sticking the stripped wires into the old connector first, to be sure)
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) Last edited by JJorgensen52; 02-19-2011 at 09:08 PM. |
02-20-2011, 09:47 AM | #20 |
DND Trucks
Thanks to all for the info, this is a really useful install.
02-20-2011, 09:50 AM | #21 |
I'll never buy those china made low dollar headlights again. I have never seen any that were any better than a mini mag light. They claim to be DOT, but I'm willing to bet you won't get converson lights with a real DOT cert for less than $60 a piece.
The relay will, but the jeep headlights are 7 inches... GMC has smaller lamps. |
02-20-2011, 09:01 PM | #22 |
Hey-I got a set of those Jeep lights just sitting out in the garage.
(I wonder if my wife would notice we traded)
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
02-20-2011, 10:57 PM | #23 |
sweet, thanks for the info
1970 Chevy K20 Custom Camper 1996 Chevy Impala SS 2008 Chevy Avalanche LT3 2003 Honda Accord EX 2001 Hewes Redfisher 16 Fighting Lady Yellow Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118 |
02-22-2011, 01:05 AM | #24 |
The Jeep lights will throw a better and more consistent light pattern than most of the aftermarket lights.
I can say from experience that relays are a must if you upgrade the lights on these trucks. I killed several dimmer switches before installing the relays. Jeep Cherokees from the mid 80's have a bracket on the right inner fender with several of the common cube relays that is easy to get. I took as much wire as I could get with the set I got. I went through several sets of H4 lights that had the clear lens and etched reflectors and was never satisfied with them. I finally went with these. http://cgi.ebay.com/ebaymotors/7-H60...Q5fAccessories With the 55/100 White bulbs you can't outrun them on high beam. They run pretty close to the Cibies I had in the 48 years ago. That seller is excellent to deal with too and his lights are first rate. I might just be hunting an unsuspecting Jeep though. Last edited by mr48chev; 02-22-2011 at 01:10 AM. |
02-22-2011, 09:01 AM | #25 |
Cibie Bobis. That's all I needed to hear. Best alternative to landing lights ever. If those lights throw a beam like those,I'm sold!
