01-03-2018, 12:51 PM | #1 |
65 C10 bagged and turbo 5.3 Ls - Build
Finally joined here and figured I'd put the current build up.
1965 C10 long bed w/ PB stage 3 front drop member, 3" drop spindles, Michigan Metalwork's flat control arms, Dominator 2600 bags, Shaved dash, firewall, and pinch welds, 22" transports, CPP drilled/slotted Currently working on: We were going the wishbone 3-link route for the rear. Decided to change it up and go triangulated 4-link. Ordering parts to build the cast 5.3 LS motor and 4l80e up to handle a good amount of boost. Planning to run a big single s480+-
Current - 65 C10/Turbo LS/Bagged Current - 32 Pickup Sold - 71 C10 Sold - 66 C10 Last edited by Goodfellers_Kustoms; 01-03-2018 at 04:19 PM. |
01-03-2018, 02:34 PM | #2 |
I'm just glad to be here!
Re: 65 C10 bagged and turbo 5.3 Ls - Build
Welcome to the forum!
Looks like its off to a good start. Who's valve cover adapters did you use on the LS?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-03-2018, 02:43 PM | #3 |
Love that color combo. Which intake is that?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
01-03-2018, 03:02 PM | #4 |
Cool truck! Question, where did you find 3.5" drop spindles?!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
01-03-2018, 04:12 PM | #5 |
Thanks, went with ICT Billet for the adapters. works perfect even has the stock o-ring type gasket milled in.
Current - 65 C10/Turbo LS/Bagged Current - 32 Pickup Sold - 71 C10 Sold - 66 C10 |
01-03-2018, 04:15 PM | #6 |
Same here, for a short time I had owned a matching 66 c10. Driveway looked good.
The intake is an ICT Billet intake, picked up due to being cheaper then the Holley sniper.
01-03-2018, 04:18 PM | #7 |
typo meant 3" but they're CPP drop spindles.
01-03-2018, 10:27 PM | #8 |
One foot in front of the other
Welcome to the forum.
01-04-2018, 01:04 AM | #9 |
60-66 Nut
Good looking build you have going on.
01-09-2018, 04:10 PM | #10 |
Been bad weather and busy lately. So figured I'd post some of the truck sold couple months ago.
02-13-2018, 04:37 PM | #11 |
Finished up reworking the suspension. Currently I have the frame stripped down, and sending parts off to powder coat.
02-13-2018, 05:14 PM | #12 |
awesome! similar to my build but yours is cleaner. Following along
02-13-2018, 08:28 PM | #13 |
How do you like the Michigan metalwork arms? I asked about them while back as a cheap option and only heard bad reviews about the company. Project looks great
02-13-2018, 09:35 PM | #14 |
Keep the updates coming.
02-14-2018, 08:53 AM | #15 |
I like them, was kind of skeptic on strength at first but these things are built thick man.
02-15-2018, 10:02 AM | #16 |
Maybe yall can help me out.
The Frame will be coated Por-15 black but having a hard time deciding on which color to go with for powder coating. Going to do the front cross member, A-arms, Shock mounts, Motor mounts, Trans cross member, Rear 4-link bars. Open to suggestions
02-15-2018, 11:05 AM | #17 |
silvers or grays go with the engine color pretty well
02-15-2018, 03:13 PM | #18 |
I agree with "bentbolt" grays and silvers will go well with the motor colour and then give you some contrast from he black frame. personally i would do a dark gray like a graphite or charcoal gray.
02-16-2018, 08:40 AM | #19 |
Thanks yall, I was thinking the same thing. Going with a charcoal or graphite with a little metallic to give it a slight pop from the frame but not to much.
03-05-2018, 12:29 PM | #20 |
Finished painting the frame last week. Also picked the stuff up from powdercoat over the weekend. Decided to change it up last second, and went with a bronze. Camera doesn't do this color justice
Current - 65 C10/Turbo LS/Bagged Current - 32 Pickup Sold - 71 C10 Sold - 66 C10 Last edited by Goodfellers_Kustoms; 03-05-2018 at 12:40 PM. |
03-06-2018, 09:17 PM | #21 |
Looks good. I think the hardest part of my build is deciding color and what part gets what color. I've got a big bag of titanium bronze powder that I once had decided on and now I've changed my mind. So frustrating LOL
03-12-2018, 01:52 PM | #22 |
slowly going back together. I've been waiting on engine and turbo parts to come in.
05-21-2018, 10:58 AM | #23 |
05-21-2018, 05:18 PM | #24 |
Liking the color combo, looks good together.
02-05-2019, 04:08 PM | #25 |
disappointed to say that we havent made much lead way on the truck. Parts are sitting on the shelves. Work and life have gotten in the way
On a good note tho we're in the process of moving shop.
