06-15-2019, 04:51 PM | #1 |
New to me '77 Silverado - Light blue original paint - 2 leaf springs!??
Greetings from Ontario, Canada...I've been on the site a while and I have just finished a 5 year long Apache build, only to find myself picking up a '77 a couple weeks ago. All original with great color and patina - I coudn't pass it up and now the '59 is for sale.
It has: 305/TH350 with a 3:07 or 8 gear. A/C not working, tilt column, drives fine and all gauges work Question for those much wiser than I: It looks to me like the P.O. wanted to lower the truck and did so by removing leaves. I assume he just cut the front coils, judging by his method on the rear here. I'd like to get 2 more inches of drop front and back. With only 2 leaf springs right now, what would be your suggestion to safely get two more drop? I did a short ride in the truck and the suspension felt fine enough. However, I also have a '74 shovelhead that I may want in the bed from time to time. Maybe I need some air helper shocks to pump up when that happens..... Thanks for your help! Gribbs Last edited by Gribbs; 06-15-2019 at 05:00 PM. |
06-19-2019, 09:54 AM | #2 |
Re: New to me '77 Silverado - Light blue original paint - 2 leaf springs!??
I would buy new leafs and do a flip kit. Correct the mistake instead of making it worse. That was a "I dont want to spend any money" lowering kit. lol
06-19-2019, 09:19 PM | #3 |
The Peacemaker
One of my favorite colors, congrats!Had a 2wd '79 blazer the same color.
My suggestion, get new leafs and get a 5/7 McGaughy or Belltech drop and install that so you have new spindles, springs (front and rear), and shocks. Regardless of which you choose, you can get the air-over-leaf air helper spring kit (instead of air shocks) to help.
1978 Chevy 2wd Stepside aka "Audrey" Cordova brown with mandarin guts 79k original miles & being restored 1979 Chevy 2wd Short Wide aka "Emma-Jayne" Cordova brown with mandarin guts 2019 Chevy Tahoe LT Previous rides: -2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB. |
06-19-2019, 11:45 PM | #4 |
Thanks guys. You’ve confirmed what I had in mind, pretty much.
06-20-2019, 02:57 PM | #5 |
First off that is a very cool truck -- in any condition. I wouldn't be able to pass it up either. That blue looks good whether it's chalky and neglected or bright and shiny. Envy. And you may know this but the ochre color in the trim is a 1977 only occurrence. And it goes particularly well with that blue. Envy again.
2nd, you've received good input. Cut coils perform fine for many and some swear by them, but to go lower in front you'll need the dropped spindles -- several mfrs available and a search for spindles or dropped spindles should net a lot of background. The 2 leaves out back sounds hokey but it appears they did a clean job of it. A flip kit should put you in neighborhood you're looking for height-wise and get your load capacity back up but again, air-bags/shocks may be required to keep the necessary clearance to carry your motorcycle. Again, various mfrs, search helps. lRCC Western Chassis has some fans. My stuff is Bell-tech, well known name but also known for some clearance problems. Welcome to square land and please consider making a build thread about whatever you decide to suspension-wise, etc. I'm sure I'm just one of many who'd enjoy seeing you make that little blue truck be the way you want it. |
06-20-2019, 04:02 PM | #6 | |
