Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-11-2019, 05:13 PM   #1
pimpston65
pimpston65's Avatar
WTB correct rag joint
If some one could please help me find the correct rag joint for a 66 K10 manual gearbox. Mine doesn’t have a flat spot in the splined section, if more dimensions are need for this item please respond, thank you.
pimpston65 is offline   Reply With Quote
Old 02-11-2019, 11:39 PM   #2
BLK65K10
Re: WTB correct rag joint
I will round one up and send it. Thanks Lyle
BLK65K10 is offline   Reply With Quote
Old 02-14-2019, 06:31 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
That's interesting , parts book lists two different part numbers for 63-66.5689757 coupling and lower flange. 5682485 Intermediate shaft flange same as for 60-62 but EXC 4WD. Does the one you have got any casting numbers on it?
Old 02-14-2019, 06:35 AM   #4
aerotruk63
aerotruk63's Avatar
Quick internet search Chevrolet passenger car has the same 5689757 part number as well as Buick's.
Old 02-14-2019, 08:48 AM   #5
pimpston65
pimpston65's Avatar
i will check for the casting numbers. my 65 2wheel drive has one with a flat spot on it, but its a newer steering box 67 i think. while my 66 burb 4x4 doesnt have a flat spot its all splines, and the 65's is too small diameter to fit on the 4x4.
Old 02-14-2019, 02:41 PM   #6
aerotruk63
aerotruk63's Avatar
From my reading there's a 3/4" shaft and a 13/16" shaft versions.
Old 02-16-2019, 01:06 PM   #7
60-66
60-66's Avatar
I have a 5689757 rag joint NOS . C10 is same as K10
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 02-16-2019, 01:37 PM   #8
pimpston65
pimpston65's Avatar
whats the cost?
Old 02-16-2019, 08:05 PM   #9
aerotruk63
aerotruk63's Avatar
Originally Posted by pimpston65 View Post
whats the cost?
3/4 ton NOS HUB LOK.
Old 02-16-2019, 10:03 PM   #10
franken
Not sure if it helps, but...
https://www.google.com/search?q=66+K...w=1171&bih=653
Old 02-16-2019, 11:42 PM   #11
pimpston65
pimpston65's Avatar
ur killing me, but i look for a set.
Old 02-16-2019, 11:42 PM   #12
pimpston65
pimpston65's Avatar
Originally Posted by franken View Post
thanks
Old 02-17-2019, 08:57 AM   #13
pimpston65
pimpston65's Avatar
there was a 3/4ton burb at a bone yard ive been going to for a couple of yrs and it had the hubs, but it wasnt there last week. not sure why or where it was moved to. i will look more around the same lot to find it.
Old 02-17-2019, 11:08 AM   #14
60-66
60-66's Avatar
Sending PM
Old 02-17-2019, 12:23 PM   #15
pimpston65
pimpston65's Avatar
i’ll take it. Pm sent
