02-22-2021, 11:09 PM | #1 |
Spindles changed track width
I did Ridetech a-arms and coilovers up front on my ‘77 (the kit comes with CPP lowering spindles) and now my track width is at least 1.5” narrower and it looks weird. I bought the truck lowered with drop spindles already on it (no idea of brand). Are CPP spindles stock width while some other brands are wider ( like the ones my truck originally came with)?
77 C10 Silverado SWB - LS Swap, mechanical resto-mod 05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e |
02-23-2021, 10:37 AM | #2 |
Re: Spindles changed track width
The 'modular' spindles from CPP (the ones w/the bolt-on caliper bracket) don't increase track width like standard drop spindles will. It's only like a .250-.375" per side though (not .750" per side).
So.... If you had drop spindles already, they would have pushed track width out .250-.375" vs. a stock disc brake spindle (it's been common knowledge that drop spindles pushed the wheels out slightly). Switching to CPP's modular spindle negates that increase & is supposed to narrow the track width vs. a stock disc brake spindle. So, the CPP spindle might be a total of .750" per side depending on the measurements of each spindle.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-23-2021 at 10:43 AM. |
02-23-2021, 11:58 AM | #3 |
They probably do that so you can run wider wheels/tires.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
02-27-2021, 11:43 AM | #4 |
Proud Vet that loves the USA
Pretty sure the ride tech a-arms are narrower as well. I have them on my truck.
Bubba |
