01-15-2021, 06:39 PM | #1 |
Coolant leak from oil pan
Got the truck up and running and have been trying to figure out my coolant issue. Thought I’d post here to see. I have a LM7 in my 49 3100. Swapped the oil pan with one that has a lower profile, but seems like I have a coolant leak in one of the spots that had a hole for a bolt but my block doesn’t have a bolt hole. Anyone run into this? When it’s @ 190 seems to just pour from there.
01-15-2021, 09:05 PM | #2 |
Re: Coolant leak from oil pan
Think i found the issues. Coolant temp sensor is leaking I’ll swap it when engine is cool again. Odd that oil pan bolt is not there though.
01-15-2021, 11:11 PM | #3 |
60-66 Nut
I would have drilled and tapped the block for that bolt.
01-16-2021, 02:03 AM | #4 |
Looks like the gasket is off center on that hole
01-16-2021, 06:47 PM | #5 |
Be careful when you replace the temp sensor and don't over tighten as they will break quite easily. Ask me how I know.
01-25-2021, 09:53 PM | #6 |
Roto Reuter thats the name...
My LM7 is the same as yours. No bolt drilled / tapped there.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
01-25-2021, 10:29 PM | #7 |
01-26-2021, 09:41 PM | #8 |
Glad to hear that's all it was. Got to love an easy fix.
