Old 06-10-2012, 03:12 PM   #1
Yesca 71
ReMan Quadrajet running rich
I Just bought a reman quadrajet from Autozone and installed it yesterday. Running very rich. Alot of smoke and burning my eyes in the shop lol. I remember something about turning the adj screws all the way in and back out 1 1/2 turns. That still true???
Yesca 71 is offline   Reply With Quote
Old 06-10-2012, 03:26 PM   #2
cableguy0
Re: ReMan Quadrajet running rich
If its smoking and running that rich the adjustment screws arent going to help you. More than likely the floats need adjustment. I dont trust the parts store reman carbs as far as I can throw them. They usually seem to be worse than the one you take off to replace it with. That is the baseline adjustment for the idle mixture screws. You basically need to turn the screws until highest idle is achieved. Turn the idle back down with the idle adjustment screw and repeat the procedure with both screws until it no longer raises the idle.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-10-2012, 03:30 PM   #3
Yesca 71
Thanks Cableguy ill give it a shot.
Old 06-10-2012, 03:33 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Like was mentioned above... even thpough it's been remanufacured, you might need to take the top off and check the float levels yourself. Check for junk in the float bowl that could have gotten into the needle and seat area too.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-11-2012, 04:43 PM   #5
Wrenchbender Ret
More then half the parts stores "reman" carbs are not right. Shut the engine off & look down the throat. If gas is running in you have dirt in the needle & seat like 71 says or something wrong with the float. I woujdn't take it apart as it might void the warranty. If you know how to work on it yourself you wouldn't have bought a reman. This advise may be to late for you, but never turn in your old part till you are satisfied with the replacement. Often it is better to have your part rebuilt then exchange it for a "reman".
Wrenchbender Ret is offline   Reply With Quote
Old 06-11-2012, 05:23 PM   #6
storm9c1
*** That's interesting ***
storm9c1's Avatar
It's hard to adjust the idle mixture screws by ear (listening to RPM). I'd use a vacuum gauge connected to full manifold vacuum and adjust the screws to get the highest vacuum reading at idle. Adjust slowly to let the engine smooth out.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 06-11-2012, 06:49 PM   #7
classicgm
classicgm's Avatar
Take it back. Mass rebuilders are only known for butchering the q-jet. Your best bet is to source a quality rebuild from an online vendor who has the tools and care to do it right.
FWIW I tried the AZ reman carbs several years back and gave up after the fourth one. Now I rebuild them myself but I don't do it for anyone else unless I have the vehicle to play with.
Good luck!
1972 GMC Jimmy - 1-ton's, 383, th350, doubler, 42" swampers, lots of custom mods. Home built
All the quadrajet tech I have found on the 'net
classicgm is offline   Reply With Quote
Old 06-11-2012, 10:59 PM   #8
C-10 simplex
Unfortunately, i would have to agree. And i'm not that good at carbs; Autoparts store reman carbs are atrocities.
You might be better off getting one from a salvage yard off a similar or ballpark application.
Or a reputable rebuilder like SMI.
C-10 simplex is offline   Reply With Quote
Old 06-11-2012, 11:08 PM   #9
mud.man.rj
mud.man.rj's Avatar
First off before you take it back make sure your choke is opening or it will run very rich, if it is electric make sure it is conected to a 12v power supply and power with key on, if not opening with power to it may have to adjust it, but I would take it back if choke wire is good or choke is working properly, why waste your time, especially if not great with carbs.
mud.man.rj is offline   Reply With Quote
Old 06-13-2012, 07:43 AM   #10
classicgm
classicgm's Avatar
There is seriously a snowball's chance in hell that it's a good carb. You'll do better with a never been rebuild carb from the junkyard and a rebuild kit.
When it comes to rebuilding quadrajets, I don't know how that industry survives.
Old 12-17-2020, 10:18 AM   #11
Arkansas Trey
I recently rebuilt my quadrajet, wasnt nearly as complicated as i thought .
It does run a little too rich now , i purchased a vacume gauge and fiddled with adjusment screws , but it looks like im gonna have go back in and adjust float height .
Arkansas Trey is offline   Reply With Quote
Old 12-17-2020, 11:35 AM   #12
geezer#99
geezer#99's Avatar
Float might be fine!
Could be your ‘richness’ is because you’re idling on the power circuit.
Old 12-18-2020, 03:27 PM   #13
Arkansas Trey
How would i go about checking that ?
Old 12-18-2020, 03:50 PM   #14
geezer#99
geezer#99's Avatar
Pull the carb off and check the idle transfer slot.
It should be square. Some info here about that. It’s referring to a Holley carb but quadrajet is the same.
http://www.crankshaftcoalition.com/w...EI_distributor
Old 12-18-2020, 09:27 PM   #15
Arkansas Trey
Thanks for the link , definitely something to check next time im in there, it did mention " off idel responce" and mine seems to do pretty good there , maybe a slight studder , but never tries to die, and will idel good, even when cold with choke on.
How do y'all guys actually know when one is running a little rich , i read somewhere thatyou can smell the excess gas in exhaust fumes (which i think i can) but when the previous owner stopped by to see my progress , he was all smiles and thought it was running pretty good , and said he smelled maybe a little richness.
Before i go and start "fixing something that aint broken"
Do you know where i can find info on how to know for sure that it is running rich afterall ?
And not just overthinking things .
Old 12-18-2020, 10:21 PM   #16
geezer#99
geezer#99's Avatar
Check the color of your plugs.
Sometimes if you adjust either mix screw all the way in and the motor tries to quit then you could be idling on the power circuit.
Adjust them slowly. A 1/4 turn at a time.
