Old 12-07-2020, 05:50 PM   #1
RockinKees
RockinKees's Avatar
700R4 identification..
Hi all,
Can some one help me identifying a TH700R4 trans?
The numbers are 0WGM299B
I know this:
0= 1990
WG=?
M= 700R4
299= day 299 of 1990
B= first shift.
I can’t find where WG stands for, only model...
Who knows it and is willing to inform me?
Thanks in advance!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-09-2020, 07:20 PM   #2
Bigdav160
Bigdav160's Avatar
Re: 700R4 identification..
I thought they used a "0" for 1982 also.
I don't remember ever seeing a "W" in the identification code.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-09-2020, 08:01 PM   #3
RockinKees
RockinKees's Avatar
That’s when you have two letter digits after the year.
This one has three, so it’s a 1990.
Cheers!! Kees.
Kool Guyz CC
Old 12-10-2020, 12:43 AM   #4
clinebarger
"G" means G-Series Fullsize Van, The W would be the calibration ID (Governor)
clinebarger is offline   Reply With Quote
Old 12-10-2020, 05:22 AM   #5
RockinKees
RockinKees's Avatar
Thank you very much Clinebarger!
This is my answer
Do you know if there is a list online?
We just got a second transmission with BBM as the digits, this one is from ‘91.
Cheers!! Kees.
Kool Guyz CC
Old 12-14-2020, 11:54 PM   #6
clinebarger
B-body.....Impala, Caprice, Roadmaster.
Old 12-15-2020, 06:04 AM   #7
RockinKees
RockinKees's Avatar
Thanks again!
So in short you can say, the second letter digit tells you the body model?
Is there a way to tell the difference between L6 and V8 transmissions also?
Cheers!! Kees.
Kool Guyz CC
Old 12-15-2020, 11:42 PM   #8
clinebarger
I can't recall a 700R4 behind a I6, 4.3L V6 700R4's are near identical to V8 700R4's.
700R4's used behind 2.8L, 3.1L, 3.4L, & 3.8L V6 engines have different Bellhousing bolt patterns.
Old 12-16-2020, 05:11 AM   #9
RockinKees
RockinKees's Avatar
My bad about the L6, meant V6.
You read on the almighty interwebs that the 6 and 8 cilinders uses different internals on some parts, that’s why the question.
We now have two 700R4s and we need two more. They are not readily available overhere in the Netherlands.
They are coming in cars with a mildly tuned 350V8.
Cheers!! Kees.
Kool Guyz CC
Old 12-16-2020, 10:01 PM   #10
clinebarger
4.3L units use the same parts & friction counts as the V8 versions. It's the 60 Degree Bellhousing (245mm) units that use different parts/friction counts.
I consider ANY & ALL 700R4/4L60 units as CORES that need to be rebuilt.
Old 12-18-2020, 06:23 AM   #11
RockinKees
RockinKees's Avatar
Thank you very much, Clinebarger, appreciate your help!!
The transmission are going to be rebuild, because you’ll never know whats inside.
And, we want it right before building it in!
Thanks again!!
Cheers!! Kees.
Kool Guyz CC
Old 12-19-2020, 12:54 PM   #12
Bigdav160
Bigdav160's Avatar
There are some minor differences that can be overcome - servo, boost and line limit valve come to mind
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
