11-01-2020, 01:12 PM | #1 |
turn signal switch
I have put a tilt steering column from a 1970 Camaro in my 66 truck. I am putting a remote horn button in place of the horn ring. I have found the correct wires to change for this but I can't find what the tan-green/tan wires are for on the switch. Can someone tell me what these wires ae for?
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
11-01-2020, 01:45 PM | #2 | |
Old member
Re: turn signal switch
If so we need the info of what switch your using to help you.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-02-2020, 09:24 AM | #3 |
The best tool to have when mix/matching electrical components is wiring diagrams for both vehicles...
11-02-2020, 11:43 AM | #4 |
Msgt USAF Ret
If you are talking about the turn signal switch and two wires to it , a tan and green/tan wire. Does your signal lever also dim the lights and if so they might be the wires for the dimmer switch.
Here is a picture of a 70 Camaro tilt column switch does yours look like it.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-02-2020, 07:10 PM | #5 |
Old member
Try this link about half way down is the 70 turn signal diagram. It maybe for the key buzzer.
https://www.painlessperformance.com/Manuals/20112.pdf
