11-29-2020, 11:26 PM | #1 |
Trans line mods
Hey all.
I cut my metal trans lines to add an additional cooler. the bottom line now runs fluid through the new cooler and then it runs through the radiator as always. I put double hose clamps on the rubber line but this morning it blew the hose off. I was pulling into the shop so I caught it before any damage. Is there a way to add a bulge or swell to the metal line so the hose and clamp will not slide off? The truck has been driven three thousand miles after the install. I could reinstall it like it was but I will worry about it. What would you guys do?
68' with no bells or whistles unless I add'em. |
11-30-2020, 01:33 AM | #2 |
Re: Trans line mods
I'd put a 5/16 nut on it, double flare like a brake line then screw on a hose fitting like it originally had. Next time don't cut it. If the aux cooler fails you could have by-passed it without a lot of drama
11-30-2020, 03:04 AM | #3 |
Re: Trans line mods
You could use a crush fitting and a barb.
You could flare it, then put on your rubber hose and 2 clamps. |
11-30-2020, 11:35 AM | #4 |
Re: Trans line mods
The PO said the trans fluid passes through the aux cooler and then the radiator. It seems this is backwards as the fluid will always enter the trans at the same temp as the radiator. I.e. the radiator might raise the temp of the fluid. So, radiator first, then the aux cooler.
I add bulges to metal lines by only performing the first step of a double flare. |
11-30-2020, 11:55 AM | #5 |
Re: Trans line mods
I do the ‘poor man’s’ single flare!
Poke a piece of round stock or bigger Phillips screwdriver inside about an inch, bend it up against the inside edge of the tube and go around the inside a couple times. Makes a slight raised circle to hold the hose on leak free. |
11-30-2020, 12:08 PM | #6 |
Re: Trans line mods
I use my Mastercool tool and make a quick-connect flare but don't go all the way so it is not as tall as a quick connect. It gives a nice ridge that the hose will slide over but the clamp won't slip off of. I wish Mastercool just made a die to do a barb. I think they would sell a lot.
I did a bit more research because this is a needed thing for low pressure. The proper tool for this is a beading tool and the Parker kit is the gold standard apparently. https://www.aircraftspruce.com/catal...parkerbead.php Still think Mastercool tool should be able to do it if they made a die for it.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project Last edited by MARKDTN; 11-30-2020 at 12:20 PM. |
11-30-2020, 12:21 PM | #7 | |
Re: Trans line mods
11-30-2020, 12:55 PM | #8 |
Re: Trans line mods
Poor mans way I use a punch ,one that has a point then flares out bigger as it goes toward the handle never had one blow off. Allso I run into rad. then to the cooler then back to trans.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
11-30-2020, 01:37 PM | #9 |
Re: Trans line mods
The best way to do this without buying tools is to use a compression fitting & hose barb fitting. $15 at the local hardware store is cheap insurance on a long trip. If the OP had a flare tool he would not be asking this question.
Yes you can jury rig/flare out the hard pipe and slide the hose over it and may be good for 10 years. OR it may leak slowly and fail hundreds of miles away from home in a blizzard(my luck).
Made in America by Americans |
11-30-2020, 01:55 PM | #10 |
Old member
Re: Trans line mods
I have never had any problems with flaring the end of the tube and slipping the hose over it with 2 clamps 180* out from each other.
Putting a compression fitting & hose barb fitting is OK also. either one should hold fine as long as done right. The trans fluid should go through the radiator first then the add on to cool it down good. Chevy performance states anything over 200* is bad for the life of a transmission. I ran my 700-R4 like stated and it had right at 300,000 on it when I pulled it out.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-30-2020, 01:59 PM | #11 |
Re: Trans line mods
Two points.
1. I had an auxiliary cooler line blow off. It does not take long to pump a transmission dry. I used the rubber hose supplied by the manufacturer of the auxiliary cooler. That is what failed. I then bent hard lines to reach out to the auxiliary cooler then double clamped very short pieces of rubber hose. That was about 15 years ago. Maybe 20. 2. Regarding how to plumb in an auxiliary transmission cooler. In a cold climate like where I live you want to run the hot fluid to the auxiliary cooler then to the radiator then back to the transmission. In the winter you can have transmission fluid that is too cold. The radiator helps warm it up on a cold day. In warmer climates run it to the radiator then the auxiliary cooler.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
11-30-2020, 02:17 PM | #12 |
Re: Trans line mods
Thanks for all the help. I will make the necessary adjustments. I have a double flair tool. Never have used it. I knew I would get some good info on here.
11-30-2020, 03:35 PM | #13 |
Re: Trans line mods
Proper line routing is to radiator then to aux cooler.
Avoid all rubber hoses. When cold, fluid pressure can be very high. If you decide to make new hardlines, use 5/16 Nickel Copper alloy. It flares easily, bends fair (grease your dies or it will kink) and is DOT approved.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
11-30-2020, 08:14 PM | #14 |
Re: Trans line mods
11-30-2020, 09:57 PM | #15 |
Re: Trans line mods
https://www.amazon.com/Earls-Perform...J602NF51X3CE0D
i know theese used to be available in 3/8 and 5/16 and half inch . super easy super fast but spendy |
12-01-2020, 07:51 AM | #16 |
Re: Trans line mods
I looked up the tool Firedemon mentioned but it looks like it is for aluminum only. Summit carries it. might be of some help to some one doing a new build.
