Old 06-06-2010, 09:30 PM   #26
Devil Pup
Devil Pup's Avatar
Re: 2wd lift kit
Originally Posted by chevyblazer View Post
made mistake with the 3/4 ball joints the upper ball joints fits the lower doesnt my freind did it but he cut ball joint hole the control arm and welded the newer arm
ok so i have a 3/4 ton truck. the upper ball joint will be fine for the spindle but the bottom one has to be changed or?
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388
Devil Pup is offline   Reply With Quote
Old 09-21-2010, 09:59 PM   #27
custom72c20
custom72c20's Avatar
Re: 2wd lift kit
Any word on this? I am trying to lift my 72 c20. All help appreciated. Thanks
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 09-22-2010, 03:58 PM   #28
Devil Pup
Devil Pup's Avatar
Re: 2wd lift kit
I got some answeres, as far as a lift, what i was told had to be done was to convert to 73-82 i believe front control arms, spindles, linkage ect. . . and then buy a lift for that year. i might be off on the year but ill research my past posts around here and ill try to find out for sure.
Old 09-23-2010, 11:57 AM   #29
pooz911
pooz911's Avatar
Re: 2wd lift kit
the 71 and 72 3/4 and 1 ton susp are the same as the 73-87 3/4 and 1 ton susp. you don't have to change anything. The only "suspension" lift on the market is the Fabtech kit for the 1/2 ton 73-87 truck.
Originally Posted by DKN View Post
The fabtech 73-87 1/2 ton lift kits can be adapted to the 3/4 ton. you will need to replace the ball joints in the kit with 3/4 ton ball joints.
Danny Nix
CPP
(Fabtech Motorsports years ago)
www.cardomain.com/id/pooz911
pooz911 is offline   Reply With Quote
Old 09-23-2010, 12:08 PM   #30
Devil Pup
Devil Pup's Avatar
Re: 2wd lift kit
Good luck finding a kit. . There impossible to come by and a few grand if you do catch one. . . it was the 88-98 spindle option that some were saying would work, just gotta change the ball joints and then you can do a spindle lift. Also here is a kit made for our trucks its just not high enough for what im wanting. but heres the link in case any of you want it.
http://www.airbagit.com/product-p/x2-car-gm6387h.htm
Old 09-23-2010, 12:58 PM   #31
QKENUF4U
QKENUF4U's Avatar
Question Re: 2wd lift kit
Originally Posted by Devil Pup View Post
those arms with these spindles ??? could ya make it work ?
http://store.fatbobsgarage.com/chevy...nly-p5636.aspx
QKENUF4U is offline   Reply With Quote
Old 09-23-2010, 12:59 PM   #32
Devil Pup
Devil Pup's Avatar
Re: 2wd lift kit
Originally Posted by QKENUF4U View Post
do they make a spindle that raises your truck instead of lowering it ? do that kit with a dropped spindle and instant 6" lift ????
K you got me interested, How would you do this???
Old 09-23-2010, 01:04 PM   #33
QKENUF4U
QKENUF4U's Avatar
http://www.google.com/products?q=199...w=dd&scoring=r
if those arms would work then these spindle would work.... ????
Old 09-23-2010, 01:19 PM   #34
Devil Pup
Devil Pup's Avatar
Re: 2wd lift kit
would those spindles work with the kit considering the kit is for the older year?
Old 09-23-2010, 02:45 PM   #35
QKENUF4U
QKENUF4U's Avatar
Thumbs up Re: 2wd lift kit
no idea myself.. change ball joints ?? someone with way more knowledge will have to answer that question... if it did work that would be AWESOME !! i seen a blazer back in 1990 that was 2wd and lifted 6" or so... HAVE WANTED ONE EVER SINCE !!!!
Old 09-25-2010, 12:25 PM   #36
1FASTHOE
Re: 2wd lift kit
after reading all the links on this site, its still not clear as to what to use to lift a 87 suburban 1/2 ton 5 lug.
from what i gather, i need 4" lift spindles, 88-98, 3/4 ton lower a arms,(year)
and what ball joints do i need to buy ? (year)
thanks
1FASTHOE is offline   Reply With Quote
Old 10-04-2010, 09:31 PM   #37
custom72c20
Re: 2wd lift kit
My step Dad owns an autoparts store that I work at. Sometime this week, I will go through the parts books and see if I can find something that will work. I have a feeling that the ball joints and tie rods won't be an issue, but the brakes could be. I'll check back with the info that i gather.
Nick
Old 10-04-2010, 11:23 PM   #38
1FASTHOE
Re: 2wd lift kit
Kewl...
Old 10-30-2010, 06:12 PM   #39
396C20
396C20's Avatar
Re: 2wd lift kit
TTT
Any updates on this?
69 Chev C20 396 T400 Dana 60 3.54 A/C Daily Driver - Stolen
67 Chevy C20 CST
396C20 is offline   Reply With Quote
Old 12-31-2010, 01:04 AM   #40
63chevyll
gets board easy.......
63chevyll's Avatar
Re: 2wd lift kit
Originally Posted by 396c20 View Post
ttt
any updates on this?
x2
63chevyll is offline   Reply With Quote
Old 12-31-2010, 01:17 AM   #41
Devil Pup
Devil Pup's Avatar
Re: 2wd lift kit
You can use 73-87 lift spindles and or a fab tech kit "but they sag so you won't get as much lift as claimed by the kit.
Old 12-31-2010, 01:22 AM   #42
Devil Pup
Devil Pup's Avatar
Re: 2wd lift kit
Orry I guess I should read. The topic has changed it seems since I last posted. On the newer trucks they make different kits I think. But I did figure out how to lift a classic 2wd
Old 12-31-2010, 01:26 AM   #43
63chevyll
63chevyll's Avatar
Re: 2wd lift kit
i dont think fab tech makes 2 wd lift spindles anymore? anyone?
Old 12-31-2010, 01:42 AM   #44
69C-owner
Re: 2wd lift kit
Ok i'm gonna let the rest of u boys figure out the frontend but in my mind the best solution for the rear is to find a donor truck with a leafsprung rearend and convert ur truck to leafsprings and get a liftkit for 4x4 67-72
69C-owner is offline   Reply With Quote
