09-28-2020, 09:45 PM | #1 |
Active Member
Wiring a 700R4
How is the best way to wire a 700r4? I have one in my longhorns with no wiring for the converter lock up,
Don Brace 55 Nomad 56 Nomad 58 Impalla Coupe 58 Bel-Aire 4D HT 61 Impala CVRT 409 4 SP 2- 71 Longhorns Always looking for old toy trains, Juke boxes Pin ball and game machines. |
09-28-2020, 10:34 PM | #2 |
Re: Wiring a 700R4
Several outfits make a wiring lock up kit even Amazon is in on the deal here is a sample only...no endorsement of any one type or price.
https://www.amazon.com/American-Auto...1346694&sr=8-3 |
09-30-2020, 08:35 AM | #3 |
Re: Wiring a 700R4
What you mean no wiring ? no wiring at all or the plug is not wired up. Just google it ten different ways to do this . Is it a manual valve body or ??? Not near enough info.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
09-30-2020, 10:18 AM | #4 |
Active Member
Re: Wiring a 700R4
There is no wiring to the plug. I don't think it has a manual valve body.
09-30-2020, 08:19 PM | #5 |
Re: Wiring a 700R4
Sounds like you need to drop the pan and have a look see ,do you know if its a lock-up convertor or not. Hopefully Clinebanger will chime in and help
10-01-2020, 09:08 AM | #6 |
Active Member
Re: Wiring a 700R4
How do I determine if it has a lock up converter?
10-01-2020, 04:03 PM | #7 |
Re: Wiring a 700R4
if it does have lock up, this is the kit i recently used when removing all the factory electronics from my 89.
10-02-2020, 01:04 PM | #8 |
Re: Wiring a 700R4
I think the only true way to tell is to drop the pan and see if you have a wire harness in there.Are there any wires comming out on the pass side ,I have heard that some people just snip the wires and don't worry about lock-up.If it was me I would drop the pan and find out what is in there besides never hurts to change the filter.I take it you bought it this way so not knowing the previous owner to ask ?
10-02-2020, 01:46 PM | #9 |
Active Member
Re: Wiring a 700R4
What is the kit you used?
10-02-2020, 02:23 PM | #10 |
Re: Wiring a 700R4
I used a TCI kit in both my 63 and my 69 ,it has several differant options to hook it up.The kit Sheepdip posted looks like a good kit allso and I would be very tempted try it if I needed another one.
10-03-2020, 10:28 AM | #11 |
Re: Wiring a 700R4
Not to hijack the thread but I’ve got a question about wiring my lockup. The builder wired it internally but I’m a little confused on the exterior wiring. Truck was originally a 3spd on the column so I’m not sure where to head in on the wiring. If I buy a kit I’ll end up with a bunch of extra parts I don’t need. Does anyone know what exactly I need as far as brake switch etc? Thanks
10-03-2020, 11:09 AM | #12 | |
Re: Wiring a 700R4
1 harness will feed 12 volts to the pressure switch and the other will feed from the pressure switch to the external tranny plugin...very simple. I'm quite sure it even comes with instructions. https://www.amazon.com/gp/product/B0...Y510T9EB&psc=1 |
10-11-2020, 08:47 AM | #13 |
Active Member
Re: Wiring a 700R4
Shipdip thanks for the link. I will get one for my truck.
10-16-2020, 09:33 AM | #14 | |
Re: Wiring a 700R4
10-16-2020, 11:38 AM | #15 |
Active Member
Re: Wiring a 700R4
That connector I think will lock the converter when you apply 12 volts. You need to have a set up like sheep dip recommends.
