Old 09-30-2020, 06:54 PM   #1
Astro-Balls
Astro-Balls's Avatar
'68 tow hook install
Is there a page in the assembly manual that shows this?
Reason why I ask is it seems the Lower mounting area of the hook is thicker than the upper mounting area. Did Chevy have a washer in between the upper mount to compensate for this difference?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 09-30-2020, 07:15 PM   #2
kwmech
Re: '68 tow hook install
Is it me or is that hook on backwards?
Old 09-30-2020, 07:37 PM   #3
Richard
Yep, backwards. Not the proper mounting holes either. Tow hook mounting holes are in the pic below.
Richard
Old 09-30-2020, 07:54 PM   #4
Astro-Balls
So Does the upper mount get an inside washer ?
Are the hooks in this pic backwards?
I heard the hooks on the 67-68 were pointed forward, No?
https://67-72chevytrucks.com/vboard/...ight=tow+hooks
In this thread, they state the hooks point forward on the 67-68
Pics please,
Is there a page in the Assembly manual that shows this?
Old 09-30-2020, 08:31 PM   #5
Richard
Never seen them mounted forwards, but I have not dealt with 67-68 trucks much. Found other threads for you http://67-72chevytrucks.com/vboard/s...ad.php?t=84811
http://67-72chevytrucks.com/vboard/s...d.php?t=218219
Regarding the washer, is not one side of the hooks flat?
Richard
Old 09-30-2020, 09:43 PM   #6
kwmech
If he flips them around they may be flat
Old 09-30-2020, 11:37 PM   #7
Astro-Balls
Are there pics in the '68 assembly manual for tow hooks?
Old 09-30-2020, 11:46 PM   #8
Richard
I don't know if there is a 68 assembly manual. I have a copy of the 67-72 factory assembly manual that I have used for 20+ years and have never seen any information on tow hooks.
Richard
Old 10-01-2020, 12:11 AM   #9
jocko
jocko's Avatar
not certain about the presence of a washer, but since it's been brought up, I believe 67-68 hooks were oriented with points fwd and outboard. Not in the assembly manual, but here are pics from the 68 4WD brochure:
Old 10-01-2020, 12:27 AM   #10
Astro-Balls
Excellent verification.
Thanks Jocko.
Old 10-01-2020, 10:13 AM   #11
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Well I'll be dipped, I would have sworn they're backwards. I learn something new every day. Thanks Jocko.....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 10-02-2020, 07:10 PM   #12
Astro-Balls
There is no Flat Side, the mounting areas are offset on both sides, here are some pics..
Old 10-03-2020, 06:33 AM   #13
Ol Blue K20
The only thing I can think of is spacer/washer. I have never looked at the earlier hooks much.
Dale
Old 10-04-2020, 01:04 AM   #14
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
They were made that way for tbe 60 to 66 trucks, on those they were mounted sideways.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
