Old 11-12-2019, 08:57 PM   #1
bruce1357
Rear Axle swap.
I have an all stock 1965 C10. I am purchasing a doner frame from a 1974 C10. I was only going to use the front cradle to do the disc/power/sway swap. As I kept looking at it I began to wonder if the rear Axles can be swaped into my 65 rear end so that I have 5 lug all around ????
bruce1357 is offline   Reply With Quote
Old 11-12-2019, 09:05 PM   #2
SkinnyG
SkinnyG's Avatar
Re: Rear Axle swap.
I believe the axle is wider. You could swap the entire axle....
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 11-12-2019, 09:06 PM   #3
PGSigns
PGSigns's Avatar
Re: Rear Axle swap.
Nope they won't go. They are wider.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-12-2019, 09:31 PM   #4
bruce1357
Re: Rear Axle swap.
I thought so. So that 74 rear end is basically useless for any of my 65 parts.
Old 11-12-2019, 09:39 PM   #5
Clyde65
Clyde65's Avatar
Re: Rear Axle swap.
You could maybe use the gears.
The 74 is 1.5” wider and can go under your 65, need trailing arm mounts, leaf mounts remove and new panhard bar.
Or...pull your 65 axles and get them welded and redrilled for 5 lug, don’t forget to get the center turned a little to fit 5 lug wheels!
Or go aftermarket and get new Moser axles that will fit and have 5 lug.
Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-13-2019, 12:57 AM   #6
Captainfab
60-66 Nut
Re: Rear Axle swap.
You can put the complete '74 12 bolt under your '65 (cutting and welding required) or you can simply purchase aftermarket conversion axles for your '65 12 bolt. I would only have the original axles plugged, drilled and machined if the wheel bearing surfaces are very nice.
Old 11-13-2019, 01:46 AM   #7
SkinnyG
SkinnyG's Avatar
Re: Rear Axle swap.
I looked into getting my 9" axles re-drilled for 5 on 5, and it was about the same price to get new axles. I got new axles.
Old 11-13-2019, 11:34 PM   #8
Angrywood
Re: Rear Axle swap.
Let me know if you dont use that 74. I’d be interested in getting the rear gears if you part it out or dont use them
Angrywood is offline   Reply With Quote
