11-04-2019, 12:13 AM | #1 |
Another Factory AC Drier Question
I'm getting the factory AC back together on my 1970 GMC. I picked up a drier from O'Reillys. Neither port is marked as IN or OUT. I'm thinking the line leading from the condenser to the drier should go to the port on the drier that is directly connected to the sight glass.
Anyone know it that's correct? Thanks
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI Last edited by Rufas; 11-04-2019 at 03:02 AM. |
11-04-2019, 10:28 AM | #2 |
Old member
Re: Another Factory AC Drier Question
I don't think it matter's as far as operation. As far as which way is the normal way I think it may have to do with the fittings. Have you looked to see if they are different sizes. It's been a long time since I delt with one but that is sticking in my head for some reason.
Most dryer have the window in the middle of it on top anyway.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-04-2019, 03:59 PM | #3 | |
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
11-04-2019, 04:32 PM | #4 |
It does make a difference and the port with the sight glass is probably the outlet.
Open your eyeballs and take a closer look. It will be marked in some fashion. It's too important not to be marked. |
11-04-2019, 08:01 PM | #5 | |
Your info is exactly the information I was looking for. Thanks!!!
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI Last edited by Rufas; 11-05-2019 at 03:17 AM. |
11-06-2019, 10:36 AM | #6 |
I installed a factory AC setup on my truck. The receiver/dryer has both sides with female fittings. On the aftermarket receiver/dryer I bought it had one port clearly marked "IN". That port is hooked up to the condenser. I snapped a photo last night.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
11-11-2019, 12:06 PM | #7 |
Still Green but learning
Can someone point me to the authoritative get your old AC working again thread? I am about to go through this. I know Compressor and Dryer need changing. What about expansion valve and is there an inline filter or Orifice tube? those kinds of questions.... I cant find it
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
11-11-2019, 12:31 PM | #8 | |
Old member
Factory style system. Compressor, drier, POA valve blow out all the lines, no orifice tube. Custom, again depends on what you do. Same as above but will need orifice tube installed in the line going up to the Condensor. Instead of a drier use a accumulator. Some good info here. https://www.team-bhp.com/forum/techn...ditioners.html I went with a factory look but updated to 134 A freon and used a kit from Classic air group to swap over from the big a-6 compressor to the smaller one. Mine has been in the truck since the late 80's and works well. I put the orifice tube in the connection under the battery. This is the old setup. It now has a LS 6.0 in it.
11-11-2019, 01:37 PM | #9 | |
So Now I think I am just going to put a Factory style with the 135 A6 on there, at least I think that makes sense from what I am seeing online.
11-12-2019, 11:03 AM | #10 | |
Old member
11-12-2019, 01:51 PM | #11 |
>>Blow all the lines out good and whatever you do pull a good vacuum <<
It has been mentioned a couple of times about blowing the lines out. You really should use a AC Flush Solvent. Pour it through in both directions and let it soak for awhile. The lines need to be flushed as well. You don't pour it through the compressor or the Accumulator or Dryer depending on the system. If changing from R12 with mineral oil to 134, I pour ester oil into the compressor (off the engine) and turn the compressor by hand until all the old mineral oil and the Ester oil has been flushed and drained out. Then add the correct amount of new ester oil to the system. You should be careful blowing out the hoses, evap and condenser if you have an old air compressor the uses a lot of oil. My air compressor is in good shape, but I make sure the compressor hasn't run in several hours before I blow the excess Flush out. Last edited by RichardJ; 11-12-2019 at 01:58 PM. |
11-14-2019, 01:27 PM | #12 | |
I converted to R134a. You can skip that part if you don't want to convert. I don't use the AC a lot but I do cycle it on often to make sure it works and to also send oil around the system. I'm not claiming it is the "authoritative get your old AC working again thread" but you can check it out here: http://67-72chevytrucks.com/vboard/s...d.php?t=478564
