05-31-2020, 01:46 PM | #1 |
Wet sanding
I'm finally at the next stage of restoration! Yay for me!
The roof needs to be painted base/clear while it is still on the rotisserie. All body work is done, coated with SPI epoxy then SPI 2K. Most of the roof was sanded with 320 dry paper using a 3' long aluminum sanding block and a 30" Durablock so things are nice and even. What is my next step with wet sanding? Should a coat of epoxy be used as a sealer as a final step? Is the epoxy sealer wet sanded? Thanks Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
05-31-2020, 02:02 PM | #2 |
Post Whore
Re: Wet sanding
You already have high build on the roof?..if you do and needs no more bodywork then sand your way up to whatever is recommended by your paint pds...
If you need sealer you can do it also i dry sanded up to 400g for my single stage..its a little coarse but I wanted a little extra bite... most use 5-600g..my paper work said 4-600g for final sanding prior to paint... I didnt wet sand anything till I got paint on it
05-31-2020, 03:40 PM | #3 |
Re: Wet sanding
If you’re doing a non metallic color as mongo Stated 400 is fine if you’re going to go to a metallic then you would probably want to do 600 and that would have to be wet
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
05-31-2020, 04:31 PM | #4 |
Re: Wet sanding
Thanks guys.
I'm doing the stock white roof with the blue body. Hawaiian blue maybe? The 400 would be dry sanding not wet? Paul
05-31-2020, 04:51 PM | #5 |
Post Whore
Re: Wet sanding
I'm using single stage..no metallic...I dry sanded mine...bc/cc may be different....nsb is saying metallic needs wet sanding
05-31-2020, 07:58 PM | #6 |
Re: Wet sanding
What I said is if you do 600 it needs to be wet it’s just too fine to do dry you can do 400 Wet or dry
05-31-2020, 08:05 PM | #7 |
Post Whore
Re: Wet sanding
Gotcha...I had clogging issues with the 400g...( not clogging like in the gieco commercial though)...but I could suck the primer off the paper with the shop vac and keep going
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-31-2020 at 08:21 PM. |
06-01-2020, 03:58 PM | #8 |
