02-07-2006, 09:31 AM | #26 |
Re: S-10 door rubber review time
So these attach to the cab and not the door?
do you have to drill holes?
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
02-07-2006, 10:18 AM | #27 |
More Cowbell....
The attach to the exact same location as the originals....just slip on with no glue.
Find any newer chevy truck 1988-current, and pull down on the weather stripping. It will unpinch from the metal. Then you can place it right back on and it will stay. Those are the same exact seals that we are talking about.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
02-07-2006, 10:30 PM | #28 |
Has anyone ever tried other model seals like silverado? Why the s10, just curious. The new trucks seals install the same way like putter just said.
1969 K20 not running, complete but rusty with wrecker boom and push bumper 1969 GMC C20 un-molested rust free original paint "a 4 eyed girl named 'Tina" 1971 Chev K20 4X4 Box Delete Commercial Truck Flatbed "Choose a job you love, and you will never have to work a day in your life." Confucius |
02-08-2006, 10:21 AM | #29 |
More Cowbell....
I started with S-10 ones(and for some reason mine were 1.5" too short), so my new ones are actually 2004 Chevy full-size extended cab (with extended cab doors) seals. And they are the same thing as far as I can tell.
So, just find ones from GM that are long enough and you should be good to go.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 02-08-2006 at 10:21 AM. |
02-08-2006, 11:41 AM | #30 |
Dork For Days
Has anyone tried trimming the S10 rubber to help the doors close easier?
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status! 1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60' 2007 Dodge Charger SRT-8 2008 Cadillac CTS All-American garage, baby! |
02-09-2006, 06:58 PM | #31 |
I pulled a set off of a 94 S-10 Blazer that just came in.
They were about 1 inch short but fit great otherwise. Took all of 5 minutes.Since they were already broke in the doors shut like they did before. Jim Dam I like workin in a junkyard! |
02-13-2006, 12:59 AM | #32 |
No one's tried them in a burb with the 90º upper corner to contend with?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
02-18-2006, 12:16 AM | #33 |
Old member
OK, I read all of this about the seals. Do they just magically stay on the cab(NOT THE DOOR) when you place them, what? No glue is nice but what makes them stay in place?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-18-2006, 12:35 AM | #34 |
"Trucks with Class"
I pulled a nice set out of a 90s suburban and the grooves that snap/push over the body pinch are full of sticky black goop sealant. I have never used them yet because they were so sticky. Was this an improvement to keep the water from getting in?
02-19-2006, 01:05 AM | #35 | |
02-19-2006, 01:37 AM | #36 |
Designated A-hole!
There's a clip in the rubber that grabs the lip around the door to keep it in place.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
02-19-2006, 01:45 AM | #37 |
you can crimp it to the metal lip on the cab if you have to, there is metal inside the silverado seals, done this many times on ex-cab trucks when the seals come loose.
02-21-2006, 12:51 PM | #38 |
Hi everyone.
We have stopped selling the 82-93 S10 door to cab seals, as replacements for the 67-72 trucks. The manufacturer tighten the specs for the length on the s10 seal, so it can come up short on a 67-72. We have chosen a seal that's almost identical to the s10 door seal, but this new seal has a slightly smaller diameter so the doors don't have to be shut as hard, and it's also longer. I still have the first set of S10 seals on my truck that I put on about 3 years ago, and still have to shut the doors pretty firmly, especially with the windows all shut. Les @GMCPauls
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. Last edited by 71Chev; 02-21-2006 at 12:52 PM. |
02-21-2006, 01:59 PM | #39 | |
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
02-21-2006, 02:50 PM | #40 |
They are reproduction seals, that come with a lifetime warranty to the original buyer. The seal we selected is probably used for several different applications, we selected it based on the diameter of the seal that contacts the door, and the depth of the "clip" or push on part of the seal. The 73-87 and 88-98 door seals were considered, but the seal on those is larger than the S10 seal, so it would make the 67-72 door even harder to shut.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
02-21-2006, 05:56 PM | #41 |
I just got a used set off a 97 S10. Fit perfect and shuts nicely. The seals I got look brand new and are nice and soft. I did take them back off, cause I'm getting ready to paint the truck.
1997 GMC Sierra Ext 1965 Mustang |
02-21-2006, 08:10 PM | #42 | |
Now I have a set of reproduction ones of the correct style and you've come up with some that are better yet? Arrgh!!! Just my luck...
02-21-2006, 08:15 PM | #43 |
Les, is it okay to ask the price of the new cab seals that you are selling?
02-21-2006, 11:29 PM | #44 |
Cause the Chicks DIG IT!!
Glad I read this thread!! and here I thought I was a retard and couldn't keep that stupid weatherstripping in!
03-03-2006, 07:45 PM | #45 |
Just Got A New Set From Gmc Pauls And If The S10 Ones Are Harder To Close Than These Then They Must Really Hard Too Close Because These Are Harder Than Heck Too Close Really Have To Slam Too Close And Another Thing I Didnt Like Was The Box They Came In Said They Were For A 78-93 Dodge Pick-up And I Hate Dodge Pick-ups But They Were Very Easy To Install
03-04-2006, 12:19 AM | #46 | |
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
03-04-2006, 12:50 AM | #47 |
what ever GMCpauls is selling now fit PERFECT (lenght is EXACT in my truck) worth every penny. still need to pull the doors nice and solid to shut them but they work perfect.
03-04-2006, 11:49 PM | #48 |
Turbo Guy
Just curious what a set of these cost? The s-10 ones and the ones from GMC Pauls. Thanks
03-05-2006, 07:05 AM | #49 |
50 bucks
04-05-2006, 09:36 PM | #50 |
Could someone pls post a pic of these installed. Much Thanks.
71 short fleetside |
