12-18-2019, 06:12 AM | #26 |
Re: Fabricated spare tire mount
Look up Metal Doc’s build thread. He recessed the spare tyre into the bed floor and it was almost out of site.
I love the mount you made but the c20’s taller tyre does stick up a bit.
John 69 c20, 396, th400, dana60, ps, ac |
12-18-2019, 06:17 AM | #27 |
Here’s a picture from Metal Docs build thread.
12-18-2019, 09:48 AM | #28 |
Very nice work! A vinyl cover placed over the outside of the spare would prevent leaves and debris from getting into wheel. I have mine covering the inside of my spare, but am using the original stake sides which hide the spare from view.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
12-18-2019, 10:05 AM | #29 |
Very nice! I’ve never got around to doing anything with my spare. I have a winch from a newer truck that I was thinking about using to mount it under the bed. But I don’t have much room under there with the receiver hitch and exhaust. Now I’m thinking about stealing your idea and maybe using a piece of pipe that’s threaded. Then you could screw a cap on the end to hide tools or whatever.
12-18-2019, 11:50 AM | #30 |
Very nice work, looks great!
72 C10 lwb fleetside -stock 350/350 combo |
12-18-2019, 11:57 AM | #31 |
BlahBlahBlah
I think you did a great job. And by mounting it behind the drivers seat it shouldn't bother you as much. Out of sight by the driver, out of mind.
12-18-2019, 01:18 PM | #32 |
12-18-2019, 01:23 PM | #33 | |
12-18-2019, 01:31 PM | #34 | |
My wife now calls it "the farm truck". |
12-18-2019, 01:39 PM | #35 | |
I'll post a picture when the cap is done. |
12-18-2019, 03:50 PM | #36 |
That's pretty slick, his bed floor is also raised up a bit from the drop.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
12-18-2019, 07:36 PM | #37 |
Like you I’m a bit squeamish about cutting into a perfectly good bed floor. Otherwise I probably would have done it by now.
12-19-2019, 11:57 PM | #38 |
Hey I know that guy
Do it, Do it right, Do it right the first time |
12-20-2019, 05:55 AM | #39 |
You should check out his build thread. He does some nice work. I’m sure you could learn a thing or two.
