Old 02-23-2020, 05:44 PM   #1
jdl71
jdl71's Avatar
66 k20 front shakcle replacement
I'm looking at replacing the front springs on my 66 k20, which are readily available and reasonable however the threaded pin, bushing and shackle for the rear mount are not (reasonable). I'm wondering if I could use this setup instead? I guess I need to know if the i.d. of the spring eye is the same, any other reason why that wouldn't work?
https://www.generalspringkc.com/product_p/sk-178.htm
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 02-24-2020, 01:51 AM   #2
raylube
raylube's Avatar
Re: 66 k20 front shakcle replacement
That setup will not work using stock spec springs. . Lmc has a rear shackles kit around 40 to 50 bucks each. The front spring eye bolt is the pricey one around 110 bucks each.
raylube is offline   Reply With Quote
Old 02-24-2020, 01:56 PM   #3
61K10
61K10's Avatar
have you dissembled all the pins and ft bolts? whats bad?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-24-2020, 05:33 PM   #4
jdl71
jdl71's Avatar
I thought the rear setup was more like $120 also. Is the reason it won’t work due to the size of the spring eye?
Psalm 23
64 C10
66 K20
Old 02-24-2020, 05:35 PM   #5
jdl71
jdl71's Avatar
No I haven’t yet I just was trying to get ahead of the game. Everything else I’ve touched on this truck has been completely wore out or cobbled together so my expectations of any of it being useable are fairly low.
Psalm 23
64 C10
66 K20
Old 02-24-2020, 06:23 PM   #6
raylube
raylube's Avatar
Spring eye size and spring width on rear of front spring on stock square body springs are bigger. You might be able to machine some aftermarket lift spring poly bushings to fit. But for 40 each for rear shackle kits and I believe general springs include the bushings you need I would go that route if your front eye bolts are still good. I am using 67 72 aftermarket springs that are the same length and
Modifying hangers to work
Old 02-24-2020, 07:54 PM   #7
jdl71
jdl71's Avatar
The $40 shackle assy LMC lists for $40 says 60-63. Classic Parts lists a late 63-66 for $110, but then for 3/4 ton gives the same part# as 60-63 for $120. I'm not sure which one I need or why they are different. I was hoping General spring would have those also, I'm going to call and ask before I order. They do say there are no bushings included with the front springs.
Psalm 23
64 C10
66 K20
Old 02-24-2020, 09:05 PM   #8
raylube
raylube's Avatar
CHECK THIS THREAD,http://67-72chevytrucks.com/vboard/s...d.php?t=719641 ALSO ASK USERS EVAN396, AOTTE1, 72cs20 also https://www.67-72chevytrucks.com/vbo...&postcount=223
Old 02-24-2020, 11:53 PM   #9
raylube
raylube's Avatar
http://67-72chevytrucks.com/vboard/s...6&postcount=46
Old 02-25-2020, 07:05 PM   #10
jdl71
jdl71's Avatar
Excellent, thank you.
Psalm 23
64 C10
66 K20
