05-11-2019, 09:18 PM | #26 |
Re: Steering Wheel is a half turn off after disc brake conversion
There we go! Center the gearbox and if your wheels are straight then just straighten the steering wheel. I've had to do this before when I put a quick ratio box on my S10.
05-11-2019, 11:20 PM | #27 |
Ok. I centered the gear box by dinging the stop at each end and set the box half way. The steering wheel turns 1 and 3/4 turns in each direction. The steering wheel is straight at half way from each end stop.
Unfortunately the front wheels are not straight unless I turn the steering wheel a half turn off. The tie rod ends are pretty close to even now. I will probably have to just try to alight it, but pretty sure there is not enough adjustment to get the wheels straight. Posted via Mobile Device |
05-19-2019, 11:34 PM | #28 |
one of my lower ball joints was bad so I decided that I should get that in line anyways before I worry about aligning it.
The new brake proportioning valve apparently has a crack in it, so the truck is down for a few days till I get a new one swapped in. (poor quality replacement parts are really starting to get me down on this truck. Since I am pulling the lower ball joints anyways I decided to drop the lower control arm and do it on my press. And, since I was dropping the lower control arm and, I am aligning anyways, I decided, I might as well do the Caster mod and move my lower control arms forward. I tore it all down today and I can take it and put them on the mill at work in the next day or so. It looks like I could possibly get away with moving a half inch forward. I am at 2 inches now. |
05-20-2019, 08:04 AM | #29 |
subcribing.
Curious to find what the source of this issue is... Please keep us posted (now that you're tearing into the whole frontend now |
05-20-2019, 01:40 PM | #30 |
Was getting set up on the mill to machine the new locations and when I measured the locating holes on the shaft they are 17 mm (.6693"). I was thinking this was 5/8. Maybe on the older models (this front end is from a 85 suburban). I will have to order a metric end mill.
I probably should wait till I am able to remeasure the locating rivets on the cross-member. |
05-20-2019, 03:20 PM | #31 |
Hmm. So the metric holes got me wondering. Does the 85 front end I used even need the Caster mod.
So when I look it up all I can find is this post on another site. Is this right? If the factor settings for an 85 suburban is really 8 degrees then I am more worried about the caster being too high. I should have measured caster before disassembly. |
05-21-2019, 02:05 PM | #32 |
Ok, the numbers appear to be real. I probably should not be trying to relocate my control arms forward, Also, if you are after increased caster, it looks like the suburban parts are the way to go.
Guess it is time to put this front end back together. |
05-21-2019, 04:35 PM | #33 |
At the body shop.
Is the pitman on 45° off,
if I remember correctly there's 4 positions possible ? Center the input shaft left to right then the pitman should be nearly straight to the rear or parallel with the rail.
" That didnt make it any newer " " Dont antique the equipment " |
05-22-2019, 06:31 AM | #34 |
The pitman arm can go on the steering box 4 ways, but there should only be 1 way it can go and connect to both the box and the center link.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
05-22-2019, 07:03 AM | #35 |
So, after you centered the box and reinstalled the steering wheel, how did the pitman and idler arms look? Parallel to each other and the centerline of the truck/frame rails? If not, something is out of alignment, possibly the front frame horns. This is how I figured out one of my previous trucks had a tweaked frame.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
05-23-2019, 10:49 AM | #36 | |
The pictures I posted earlier show the position of the pitman and idler arms. Posted via Mobile Device |
05-23-2019, 11:38 AM | #37 |
I've had the same issue before building crossover steering for a 4x4. What I did and what you may have to do as well is take a square file and file a groove in the 4 keyways in the pitman arm to make it fully splined. The keyways are the exact width of 2 splines (they just don't cut the one out of the middle) It takes a while but then you can clock the pitman arm however you want. I was able to get my steering wheel perfectly straight by doing this and it doesn't compromise anything in the process.
05-23-2019, 03:17 PM | #38 | |
The Older Generation
This is what I'm going to do with mine. All I have to do is get off my lazy butt and do it.... LockDoc
05-23-2019, 09:00 PM | #39 |
Thanks guys. Looks like the plan is this.
Going to reinstall the lower control arms, with no modification. Then going to see what my measurement for each tie rod is from the frame and try to balance and see if I have enough tie rod adjustment to make it happen. If not, i can try a couple more pitman arms, but otherwise there is a file. Got called by the city because my own truck has not been driving for one week. got 2 days to fix it. Got to love the stuck up people in the neighborhood. |
05-23-2019, 09:51 PM | #40 | |
Who Changed This?
05-24-2019, 09:04 AM | #41 | |
I would definitely be suspicious of the pitman arm splines being off, or the steering box having an internal problem (less likely). Is the idler arm bracket symmetrical? Maybe it’s flipped? I don’t have one handy to look at now. It does look like the idler arm is out of whack compared to the frame.
05-28-2019, 03:37 PM | #42 |
Well, everything went back together ok.
got the alignment tape measured in. Actually does look a little closer to lined up. Maybe the bad lower control arm ball joint causing to be a bit off. still not perfect, but looks align-able. Funny thing though, was just about to test drive it and something popped in the steering column. One step forward and two steps back. Greatest part is when I turn the steering wheel, the horn starts to honk. Not sure if the spring broke or the bearing cage failed or what. More fun work to do. |
