05-08-2019, 01:32 AM | #1 |
Rochester carb. rebuilder?
Anyone know if Bob Stone is still in business? I can't locate a contact for him outside of personal venues.
Found a business that goes by "carb. doctor". He's in Canada, so the added expense. Nice guy and helpful too. He offered to set me up with a complete divorce choke. OT: I wasn't sure that would work with ceramic coated high heat parts, which reduces surface temp. He thinks so long as I got the stove pipe and the crossovers are open a divorce choke should work under reasonable winter conditions. This is a Nevada garage queen anyway. I'm still on the fence though, electric is a sure thing, a divorce choke is vintage Other than that, any other carb. builders recommended? Small business types preferred. Thanks.............
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-08-2019, 05:56 AM | #2 |
Re: Rochester carb. rebuilder?
I've dealt with a local business for all my carb, starter, and alternator needs for years. But as far as a business on the national scale to suggest I would say Carb Doctor. I thought they were in PA, though. I understand they do a great job of building the carb for evilethanol exposure.
05-08-2019, 12:54 PM | #3 |
I would contact Quadrajet Power LLC, they're out of Texas. They rebuilt my Quadrajet and have great customer service too. https://quadrajetpower.com/
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
05-08-2019, 07:47 PM | #4 | |
Say Tim, another question. I'm losing the external voltage regulator, any suggestions for a replacement that's internally regulated? ________________________________________________________________________________________________ Edit: For what it's worth, here's Rusty's response. I don't know what a M4ME choke is yet. Sounds like 4MV is a divorce choke. I may have been wrong about the crossover, don't know what a "crossover choke" is, though I think he means the crossover in the intake. Be a twist if a divorce choke actually worked better because of ceramic coatings. Hello, This is Rusty (redacted). Over the years there have been a few Carburetor Doctors. I thought I was the last one, online at least. Briefly, the best set up to use depends on which carb # you have and which manifold you're using. Ceramic coatings help retain heat inside the exhaust, which helps the crossover choke. The lack of a heat riser impacts the choke. In any case, for anything other than full-out winter operation the 4MV type choke would be fine. But it depends on which carb you're going to use. The simplest solution is a late style M4ME electric choke carb. Out of the box, this carb would work well: http://carburetordoctor.com/carbs/A246.html Restoring your 7041209 would cost $375, choke parts to fit a 1971 cast intake would run about $75. Time required for the restoration is around 8 weeks or so. Regards, Rusty
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-08-2019 at 08:33 PM. |
05-08-2019, 08:09 PM | #5 |
Do you mean this guy.
https://carburetor.ca/ As for your divorced choke working in cold weather. I used them for years before electric ones came out. Good down to 40 below. Might of had to fine tune them a bit. You can’t expect them to just bolt on and work perfectly. And remember the dollar difference. You’re gaining 30% on your buck. |
05-08-2019, 08:20 PM | #6 |
Cliff Ruggles is about the best in the business for Qjets
https://cliffshighperformance.com/
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
05-08-2019, 08:56 PM | #7 |
Lars. He is a qjet guru
05-08-2019, 11:30 PM | #8 | ||
Lars?
05-08-2019, 11:44 PM | #9 |
The exchange rate.
You buy a carb for 300 bucks Canadian, you pay 200 US bucks. Here’s Lars. https://www.digitalcorvettes.com/for...ad.php?t=88376 |
05-18-2019, 11:44 PM | #10 | |
05-19-2019, 03:09 PM | #11 |
This shop rebuilt a Rochester 2 barrel for me a few years back. Did a nice job.
Carburetor USA http://www.carburetorusa.com/default.htm This might be the one Special K was referring to in PA.
1971 C20 LWB Cheyenne 396/TH400 2017 Chevy SS - Holden conversion 2015 Chevy SS 2013 Acura MDX |
05-20-2019, 05:24 PM | #12 |
Bob Stone- 267-467-6018
Located in Pennsylvania |
