05-18-2019, 06:01 PM | #1 |
Anybody try to straighten a bent tailgate?
All the tailgates that I have looked at for a 1968 Chevy C10 have been bent or curved. Is there a way to straighten a old tailgate or is it even worth it as it may not be as strong afterwards once it has been bent.
Maybe just buy a new one. I like the idea of finding a good original but I dont think that exists or are very rare. |
05-18-2019, 06:17 PM | #2 |
Re: Anybody try to straighten a bent tailgate?
Not an easy fix, I think you have to peel off the front. Remove spot welds and straitened out the pieces and put back together. I wasted a lot of time trying to slide flat bars and pull, clamp and reshape. It doesn't work. Clean take offs, from a camper could run... $900.
05-18-2019, 06:56 PM | #3 | |
05-18-2019, 07:54 PM | #4 |
The Older Generation
You might read through this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=578233 There are a few more if you type straighten tailgate or flatten tailgate into the Google search box at the top of this page, click on the circle in front of 67-72chevytrucks.com, and click on the GOOGLE button..... LockDoc
05-18-2019, 08:13 PM | #5 |
It's not impossible to straighten a tail gate, just not easy. I have friends that can DO anything. I do have one that needs to be split apart and massaged...I'm not scared...
There's still many good used units around. Become a paying member and post a "Want to buy ad". |
05-18-2019, 08:22 PM | #6 |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
05-18-2019, 08:29 PM | #7 |
What a waste .
05-19-2019, 01:36 PM | #8 |
That is odd. I'm pretty sure that a running Chevy pickup of that vintage will bring at least a thousand dollars around here, no matter how bad it is.
05-19-2019, 03:07 PM | #9 |
Nothing bringing that truck back. Back to the subject at hand, could you tack allthread to it then run a piece of Chanel along those to draw it back straight.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
05-20-2019, 09:28 PM | #10 |
I've fixed a tailgate that was pushed in from the outside, but not fixed a bent one.
The tailgate looked like it was hit from the outside and pushed where the letter M is. I drilled out the spot welds on the sides and across the bottom and cut across where a bend was. This made it easier to hide the weld seam. Then it was easier to straightened out the bend area. Then just welded it back together, one spot at a time. It was a lot easier than trying to bend it back while it was still in one piece or trying to pull the panel out with a stud puller. I think it turned out pretty good. I liked the idea of using and original tailgate instead of a repop.
1972 GMC 1500 Super Custom, 383 Stoker, TH350 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592157 Engine Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592233 |
05-21-2019, 12:41 AM | #11 |
Looks great! Guess a guy could do the same on the inside.
05-21-2019, 07:12 AM | #12 |
I was never able to straighten a bent one.....but I have bent a lot of straight ones...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
