05-16-2005, 07:33 PM | #1 |
compression
My supposedly stock '94 350 has 180 psi in 7 cylinders, and 185 on 1. Per Chilton, compression ratio is 9.1.
This seams high; engine carboned up? The procedure I followed was to remove all plugs, then crank engine over 3 compression strokes, recording all three (generally 130psi, 150psi, then 180psi). Any oppinions as to wether these numbers are normal for an engine with 50,000 miles? Thanks, Roger. |
05-16-2005, 07:42 PM | #2 |
with the tiny cams in these engines (just like my '95 Yukon) those numbers are probably in the ballpark of stock. I hate to admit I've never shecked mine in 6 years.....
'72 C10 lwb 454/TH400 |
