05-28-2020, 04:41 PM | #1 |
WTB high hump trans tunnel
Looking for a high hump transmission tunnel cover.
Thanks, Mike |
05-28-2020, 10:40 PM | #2 |
Re: WTB high hump trans tunnel
What year? 2wd or 4wd?
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
05-29-2020, 01:10 AM | #3 |
73-80 style 4wd should work.
Thanks, Mike |
05-29-2020, 09:08 AM | #4 |
Do you need the 2 pieces? What exactly are you building? LS conversion?
05-29-2020, 01:22 PM | #5 |
Is this what you are looking for? I have not actively sold for a while and do not know if I can reply to WTB ads.
James |
05-29-2020, 04:47 PM | #6 |
I’m swapping in an Ls mated to a T56. I have an 87 cab 2wd low hump that’s off the frame getting painted and undercoated. After talking to another member about the same swap I want to go ahead and put in a high hump before reassembly. Hey James that appears to be what I am looking for. Thanks, Mike
05-29-2020, 07:06 PM | #7 | |
05-29-2020, 09:26 PM | #8 |
1774btcrew, thanks for the info, I wasn’t aware that there was bolt in hump available for the 81-91 body style. I’ll keep up the search.
05-30-2020, 09:45 AM | #9 |
On the 81-83 4wd bolt in hump, the section of the cab under the seat is raised compared to a low hump cab. You will either have to modify/raise the rear section or cut the rear section out of a 4wd cab and weld in
The 84 up 4wd floor high hump is molded (non bolt in) into the floor. Your truck being an 87, an 84 up hump is a better match as where they meet the firewall changed slightly in 84. Second easiest would be an 81-83 bolt in hump with corresponding rear section welded into the cab. The 73-80 hump takes more cab massaging compared to the others to put in an 81-up cab. If I remember when I get home from work I can get pictures of and 81-83 4wd bolt in hump sitting in a low hump cab, and also the differences between the 81-83 and 84 up 4wd floor humps |
05-30-2020, 10:26 AM | #10 |
44th Miss Inf,
Thanks for the info! Mike |
05-30-2020, 09:37 PM | #11 |
Ok, hopefully this will be clear as mud
First two pictures are of an 84 up 4wd 4 speed hump at firewall and near/under the seat 3rd picture is the 81-83 4wd 4speed hump (this one has the section around the transmission hole cut off center, and turned around placing the hole rearward 3” for an NV4500 swap, retaining original shift boot etc) on an 87 low hump tunnel. Looking thru the t case shifter hole, you can see where it doesn’t conform to the floor, leaving a gap, but this is easily massaged to work. The last picture shows the gap at the back of the bolt in hump (about 1.5 inches) that you will either have to raise the t case hump to match, or install the rear hump piece from the cab you got the hump from. I did not get home in time to go to my other place, as I have an 86 2wd 4 speed truck I can compare the hump to the 4wd one, as I believe the 73-80 2wd and 4wd humps are different. I only own 81-up trucks now. |
06-06-2020, 10:41 PM | #12 |
Did you get one of these yet? I picked one up
06-06-2020, 10:57 PM | #13 |
I actually bought one yesterday kinda local, looks like it will work out. Thanks for looking out for me though!
06-08-2020, 09:15 PM | #14 |
Local is great! Were you able to get a piece of the rear section as well?
06-09-2020, 10:23 PM | #15 |
It actually fit pretty well but took a little bit of fab and finesse. Thanks for checking in on it!
Mike |
06-09-2020, 10:30 PM | #16 |
I sold one to a friend and hadn't asked him how it fit. Ii am glad they fit pretty well
