Old 11-07-2014, 10:09 AM   #151
reaper71
reaper71's Avatar
Re: "Project Orangepeel" 52 A.D
In this pic if you look close you can see how it works..I put a nylok nut on the carriage bolt so it will not loosen. and you can see the arm for the latch so you push it in and "pop"
reaper71 is offline   Reply With Quote
Old 11-07-2014, 10:18 AM   #152
reaper71
reaper71's Avatar
This is a pic of my door popper I ended up having to use this do to the weight of the door (spring wasn't strong enough) so I had these lying around the shot your looking at is from inside the cab at the "B" pillar I used the stock hole that a door bumper goes through and drilled it out to fit the plunger. then I made a plate to weld into the pillar in the center of this I used a collar stop for the popper to slide through this is used to be able to adjust the tension.
Old 11-07-2014, 10:23 AM   #153
reaper71
reaper71's Avatar
This shows a better look of how it will work..
the popper can slide forward and back to get or take away tension and the collar on the backside of pillar has a set screw so you can lock it in place..
Old 11-07-2014, 10:29 AM   #154
reaper71
reaper71's Avatar
These two pics show the stock style striker pin..the 2nd pic is my design I came up with the reason for this is just so you don't have that harsh "metal sound" when you close the door. First i took a button head cap screw the length I needed and took nylon bushing the same Dia of the stock striker then I tapped the nylon this will help it from just spinning. The end result is a quiet closing door...
Old 11-07-2014, 10:32 AM   #155
reaper71
reaper71's Avatar
This is just a final look at the door after welding and metal finish and the end of this task. On to the next...
Mark...
Old 11-07-2014, 06:20 PM   #156
Advanced Design
Advanced Design's Avatar
Awesome work! Very creative. Thanks for sharing this, Mark.
Advanced Design is offline   Reply With Quote
Old 11-08-2014, 07:21 AM   #157
RockinKees
RockinKees's Avatar
That is really nice fabwork!!
Great How-To!!
One question please:
Does this work with most bearclaws or must I have a particular one/brand??
I'm thinking of do this on my '59 also?
(Sorry to hijack this into your build, but as everybody reads this ;-)... )
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-08-2014, 10:03 AM   #158
reaper71
reaper71's Avatar
yes it will work with any brand just make sure the latches are of good quality. The main reason I used the single style. Aka medium size
Great How-To!!
Old 11-08-2014, 10:05 AM   #159
reaper71
reaper71's Avatar
sorry oat connection to internet
I used the medium latches over large because they are easier to adjust...
Old 11-08-2014, 10:20 AM   #160
reaper71
reaper71's Avatar
this the medium size latch..about 45.00 for the set
You can get then from( Rocky hinge) they have alot of really nice products if you go to the accessories section their is several items you can get to make things easy to install handles etc.
Old 11-08-2014, 10:38 AM   #161
FarmerSid
FarmerSid's Avatar
Thanks for the info and updates. What's your plan for the trim ring on the outside?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 11-08-2014, 10:40 AM   #162
RockinKees
RockinKees's Avatar
Thanks Mark!
I asked this because the few Apaches I saw, are all a hell to get the doors closed in a normal way.
I think it's a lot saver also to mount bearclaws instead of the sock locks.
You have a great How-to to this part of the build, especially for a newby like me!
Cheers!! Kees.
Kool Guyz CC
Old 11-08-2014, 08:44 PM   #163
reaper71
reaper71's Avatar
on the trim ring the bushing is the trim ring it has a shine from the mfg. So it will not need anything done to it..
Old 11-08-2014, 08:50 PM   #164
reaper71
reaper71's Avatar
Kees you are very welcome... if you ever have any questions feel free to ask...always willing to help out a fellow builder...
Mark...
Old 11-10-2014, 10:31 AM   #165
reaper71
reaper71's Avatar
This will be the next phase of my build it will be very time consuming...first the dash, I didn't want to go with just stock..I find myself checking out trucks at shows only to find nothing done with the dash besides gauges. The outside will be very stock-ish looking so I wanted the interior to speak for itself so here go's..
pic 1 and 2 are the stocker before I cut
Old 11-10-2014, 10:35 AM   #166
reaper71
reaper71's Avatar
This was the result of cutting out the stock unit if you notice I left a strip along the top this will be used as a mounting point for the new piece. I wanted this to be a removable item for welding,metal finish etc.
Old 11-10-2014, 10:39 AM   #167
reaper71
reaper71's Avatar
So after this was removed I then decided to use the upper portion of the dash for support in the 2nd pic it shows how it looked at this stage.
Old 11-10-2014, 10:41 AM   #168
reaper71
reaper71's Avatar
This pic shows a closer view of the mounting area if you look close the button head cap screws go through the stock strip and into the new mounting strip.
Old 11-10-2014, 10:46 AM   #169
reaper71
reaper71's Avatar
In this pic it shows the mounting strip i used this was welded to the stock dash, the round bar was used as a spacer.
Old 11-10-2014, 01:57 PM   #170
RockinKees
RockinKees's Avatar
Great idea, a removable dash!
Ofcourse you know in your head how it will look when finished, but you're not gonna tell us??
Cheers!! Kees.
Kool Guyz CC
Old 11-10-2014, 06:48 PM   #171
Advanced Design
Like a good movie / story / book looking forward to the next part. So the section of original dash is placed on top of the narrow strip that was left spot welded in?
Old 11-10-2014, 09:08 PM   #172
reaper71
reaper71's Avatar
haha soon enough!!
Old 11-10-2014, 09:13 PM   #173
reaper71
reaper71's Avatar
to answer your question. The strip is from the original dash and the new section bolts in from the under side, so it will be flush.
Originally Posted by Advanced Design View Post
Like a good movie / story / ook looking forward to the next part. So the section of original dash is placed on top of the narrow strip that was left spot welded in?
Old 11-11-2014, 09:35 PM   #174
reaper71
reaper71's Avatar
so in this update I hope these pics help clear up how it mounts.the plate bolts to the flange leftover from stock dash..
Mark..
Old 11-12-2014, 10:36 AM   #175
reaper71
reaper71's Avatar
This just shows how the shape was started, I made a template from cardboard then transferred this to a scrap piece to "practice" on..then i finally transferred the entire shape to metal. I used 20gauge steel for this.
