11-27-2012, 03:34 PM | #1 |
1950 GMC clock
I have done searches here and other sites but could not find information on the clock that was in my truck. I can wind it to set it but there either was no wire attached or someone removed it. I have not taken it apart. Was this an option or did it come stock?
11-27-2012, 03:49 PM | #2 |
Re: 1950 GMC clock
Do you wind from the back?, Is there a part # on the back? Very cool part.
11-27-2012, 04:29 PM | #3 |
Re: 1950 GMC clock
You should send it to me and I will test it, fix it and use it until further notice
That is coooool |
11-27-2012, 06:17 PM | #4 |
Re: 1950 GMC clock
Is that for a 47-53 truck??? Never seen one before. does anybody have a pic with it in the dash?
52 Chevy 3100 |
11-27-2012, 06:19 PM | #5 |
Re: 1950 GMC clock
That has to be somewhere in the league with rooster teeth for being rare. Have you got a photo of it in the dash?
If there is a separate "wind" knob it may be a mechanical clock.
11-27-2012, 08:09 PM | #6 |
Re: 1950 GMC clock
These are some more pictures. I opened the inside and it had inscribed The Geo. W. Borg Corp Chicago USA. #150997.
11-27-2012, 09:20 PM | #7 |
Re: 1950 GMC clock
Wow, that is cool. Well Id set the time on that baby and put 6V to it and see what happens.
Id probably do it on a bench with a power supply or a battery first.
52 Chevy 3100 |
11-27-2012, 09:26 PM | #8 |
Re: 1950 GMC clock
I keep an old clock link and did not see this clock.
You need to check the GMC web site - www.oldgmctrucks.com - the guy that runs the site or someone would know if it was an option or not. The earliest factory clock I've seen in GM trucks is 1954. |
11-27-2012, 10:11 PM | #9 |
Re: 1950 GMC clock
Your dash photo looks so cool.
Sweet cab! |
11-27-2012, 10:46 PM | #10 |
Re: 1950 GMC clock
That clock is the best thing that has happened to the radio delete cover !!
11-28-2012, 02:29 AM | #11 |
Re: 1950 GMC clock
I posted a question on oldgmctruck website and
Will update this thread. When I removed the clock From the dash it looked like the radio delete plate Had been cut in the middle to fit the clock. But the Faceplate over the clock seemed to match the dash Perfectly as to curve and paint color. Posted via Mobile Device |
11-28-2012, 06:37 AM | #12 |
Old Heap Driver
Re: 1950 GMC clock
That's a wind up clock, power would go for a light only. A friend of mine has a similar clock in his 51 Delivery. The clock is removed, you wind her up and set it back in the dash. My friend's keeps very good time.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod. |
11-28-2012, 08:56 AM | #13 |
Re: 1950 GMC clock
Cool setup. Great looking interior too.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
11-28-2012, 11:59 AM | #14 |
Re: 1950 GMC clock
I can turn the nob and set the time but it does not seem to wind up or seem to be
able to, but I may be wrong. Perhaps the bottom flange sticking out of the bottom is for the light bulb. I appreciate the information as I am curious. Regardless, I am having the dash smoothed and painted and I do not need this clock and will probably try to sell it in the proper forum. |
11-28-2012, 02:19 PM | #15 |
Re: 1950 GMC clock
PM'ed about purchasing the clock
11-28-2012, 02:32 PM | #16 |
Re: 1950 GMC clock
Virtually all old car clocks were electrically wound, and I think the electrical connections on the back are for that, not the light. The winding mechanism was what usually stopped working first, not the actual clock works. Here's an article that might help id you want to try to fix it. The more common fix now is to have it converted using a quartz movement.
http://www.oldcarsweekly.com/restora..._old_car_clock |
11-29-2012, 04:04 PM | #17 |
Re: 1950 GMC clock
Thanks Russell Ashley, that is an informative web page you linked. I have read it and I appreciate it.
11-30-2012, 09:45 PM | #18 |
Catchy title goes here..
Re: 1950 GMC clock
12-01-2012, 10:15 PM | #19 |
Re: 1950 GMC clock
Well I took it apart and cleaned the inside with cleaner lubricant and it works.
I put 6 volts to it and it ticks away. Seems to keep accurate time. |
12-02-2012, 10:56 PM | #20 |
Re: 1950 GMC clock
Smittster, do you have anymore pics of your gmc?
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
12-03-2012, 03:19 PM | #21 |
Re: 1950 GMC clock
These are older pics. I have it in a shop in OKC getting body and paint work done.
12-03-2012, 03:24 PM | #22 |
Re: 1950 GMC clock
I like the stance!
