11-29-2019, 01:34 PM | #1 |
Front sway bar search for stock 66 - going to try salvage- what to look for?
I am planning on visiting some salvage yards and see if there any sway bars that will work for my stock height 66. From what I understand I need to be looking for 1973-1989 3/4 ton Chevy trucks. Is this right?
Also to make sure I get what I need, I think it should look like this pic from Woogeroo. This right? |
11-29-2019, 02:05 PM | #2 |
Re: Front sway bar search for stock 66 - going to try salvage- what to look for?
Probably not many installed but it's listed as an option when the front suspension switched in 63 so start your search there and they are used on 1/2 and 1-ton models also. I have a 66 with one and they are fairly common 67-72. Yes, that is the setup you're looking for.
Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
11-29-2019, 03:47 PM | #3 |
On my 64 I used a sway bar from a 76 one ton dually - it had a 1-1/4" bar on it if I remember correctly. The set up looks exactly as the one you pictured.
11-29-2019, 04:07 PM | #4 |
Definitely grab the 1 and a quarter inch bar. I got one off a squarebody 3/4 ton in a u pull it type yard. You will want to take all 4 of the clamps with bushings that the bar uses. Keep the old bushings to use while you mock the bar up. That's what I did, and the new bushings that I put on fit great.
I also had to get some frame stands to mount the front of the bar to the frame. If you have something to remove the rivets on the truck in the junkyard, you could do that, but if not, you can get new frame stands from a few vendors. I went with stock height stands because I'm still at stock height. Check out page 3 of my build thread to see how I installed mine. Yours will be easier to install since you should already have the LCA holes drilled from the factory. My 63 LCAs didn't have the factory holes
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
11-29-2019, 05:13 PM | #5 | |||
11-29-2019, 11:37 PM | #6 |
Moderator
Swaybars from 73-87 2wd trucks interchange onto earlier trucks. The larger trucks like 3/4 and 1 tons typically had larger bars on them from the factory.
12-31-2019, 02:25 PM | #7 |
Would this sway bar work for my 66 thats been converted to disc for a 72 or 73 disc?
https://www.summitracing.com/parts/clp-cpp7423/reviews/ Im trying to weigh out one that was sent to me by a buddy who was going to get this for me at $100 with the frame mounting brackets removed as well. He said its from a 83 3/4 ton. Id have to sandblast and paint and buy new bushings. Last edited by msg; 12-31-2019 at 02:32 PM. |
12-31-2019, 02:30 PM | #8 |
here is where Im at with the rebuild. Its gonna be stock height.
12-31-2019, 07:45 PM | #9 | |
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
