01-07-2024, 05:55 AM | #1 |
Coil rear U-bolts ? 68 c-10
Anyone have a good source for stock U-bolts? Thanks
01-07-2024, 06:21 AM | #2 |
70+ ( Old Skool Club )
Re: Coil rear U-bolts ? 68 c-10
Lowered my truck last year and everyone told me my u bolts would break so bought new ones from either Summit or Rock Auto, cant remember which. Oh yea the old ones came off as they should and installed the new ones anyway.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-07-2024, 10:31 AM | #3 |
I think this is the best price I found for Coil Spring rear end to trailing arm u-bolts
https://www.rockauto.com/en/moreinfo...0353&jsn=19564 You could take the spec from them and get some bent up locally. Possibly cheaper. Search google for 'las vegas truck springs'. Most of the spring shops should be able to make them. |
01-07-2024, 10:23 PM | #4 |
Thanks for the info and link guys. I bought a set from speedway and the thread pitch is off, the nut is larger and the bolts will have to be cut down. I'll just send them back. Should have checked Rockauto first. Thanks!
01-07-2024, 10:37 PM | #5 |
When I had to replace the originals on my 63, I ended up going to a local driveshaft shop. They bent up a new set for me with new bolts as well for a reasonable price and matched the length and bend of the originals without having to trim the ends. I had to replace mine as the axle had come loose more than once and thinned out a couple spots on the bolts
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
