Closed Thread
Old 02-10-2014, 07:33 PM   #176
Lou Boffa
Lou Boffa's Avatar
Re: What did you do to your truck today? Chapter II
beautiful. Yup, if I ever do a bed again, I'm taking it off the truck and standing it up...for sure!
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline
Old 02-10-2014, 11:51 PM   #177
Ridgeclimber
Attachment 1213108I got my step side box all disassembled and started stripping the box sides.
Ridgeclimber is offline
Old 02-11-2014, 12:46 AM   #178
cafetony
shifter install
cafetony is offline
Old 02-11-2014, 01:37 AM   #179
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
I visited it in the body shop , the 1936 Rolls Royce got finished and was leaving as I arrived so hopefully Guillermo will soon begin to work on it .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 02-11-2014, 03:11 AM   #180
Mike_The_Grad
Mike_The_Grad's Avatar
Disassembly and cleaning.hopefully paint tommorow.really excited for the results.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline
Old 02-12-2014, 07:11 PM   #181
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Picked up my heads from Redman's Machine in Oakhurst today. Newly refurbished 062 heads with new 1.94/1.60 valves,
new springs, and and the shop's pocket porting.
I took the heads in with the old springs, rockers and valves still attached....$550.66.
I paid $300. The "Boss" settled up for the rest as a Valentine's Day
treat for me.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 02-12-2014, 07:36 PM   #182
Elliot949
Dan Johnston
Elliot949's Avatar
treat for me.
Nice....
Elliot949 is offline
Old 02-12-2014, 08:55 PM   #183
jmorri34
jmorri34's Avatar
Bought the complete wiring harness a new rear bumper and installation kit and a new grill shell. Got the rear bumper installed and gonna work on the grill this weekend!!
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline
Old 02-12-2014, 09:14 PM   #184
UNEASYRIDER
UNEASYRIDER's Avatar
STARTING OVER ON THE BODY WORK
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 02-12-2014, 11:39 PM   #185
Mike_The_Grad
Ran the block number on my "new" motor...found out its not 350. Its 305. Same size block different bore. But its OK, because the mechanic that sold it to me is a standup guy. Im gonna get my money back and return the motor.I had already cleaned and primed it.oh well, more money towards my 350.also cleaned and painted inside frame rails and partial firewall. Also cleaned and painted trans member and motor mount brackets.picked up grade 8 bolts to reinstall both. New motor mounts came in. Received my '72 service manual I had ordered online.
Old 02-13-2014, 11:18 AM   #186
74baggedbug
Ordered all my parts for the cam upgrade.. Darn pesky lifter tap
74baggedbug is offline
Old 02-13-2014, 08:41 PM   #187
magwakeenercew2jh
Getting ready to install the fuel pressure regulator, I went out and looked at the fuel pressure gauge. it wasn't at 15, the way it seemed to be pegged on the last start-up.
It was at around 9.5. Just sitting there. No electric fuel pump "on"....So, first I pulled the gauge. It *did* move. To 7.5...while it was off. No pressure. There is a screw
at the back I figured was an adjusting screw. I adjusted it. No dice.
Couldn't get another one today, so I installed the fuel pressure regulator, hard and soft lines. Screwed the fuel pressure gauge back in. Fixed a couple of trouble spots.
I think it showed 12 when adjusted all the way out ("most clogged") while the ignition was on and the motor was not running. When I started it up, the gauge reads "9".
Guess I better get a new gauge.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 02-13-2014, 11:46 PM   #188
Z10
Z10's Avatar
Started my ZZ4 with FIRST TPI, for the first time.
Click on the photo to hear it run and click on my build thread to see more.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline
Old 02-13-2014, 11:53 PM   #189
magwakeenercew2jh
OOOOooooH!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 02-14-2014, 09:28 PM   #190
ole dollor
ole dollor's Avatar
Z10..sounds good. looks good also. like it a lot....
ole dollor is offline
Old 02-14-2014, 11:04 PM   #191
jmorri34
jmorri34's Avatar
Put the new grill on today!!
1969 cst prostreet
jmorri34 is offline
Old 02-14-2014, 11:46 PM   #192
Towstrap
Towstrap's Avatar
went out back an checked on her
Towstrap is offline
Old 02-15-2014, 02:28 AM   #193
stepsider
stepsider's Avatar
Started project Windows, Picked up the one piece window kit(no wing window) & started the the change over & mods. will post pictures later.
stepsider is offline
Old 02-15-2014, 03:27 AM   #194
In The Ten Ring
Wednesday, just as the big storm Pax was getting started, I mailed off my shipping payment to get my 1968 stepside spare tire cutout fender sent to me.
I'll have to figure out where to put that as my garage is pretty packed up.
In The Ten Ring is offline
Old 02-16-2014, 01:13 AM   #195
Z10
Z10's Avatar
I drove it for the first time since June!
Click on the pic to see video.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline
Old 02-16-2014, 01:42 AM   #196
stepsider
stepsider's Avatar
1 piece window did pass door today
Old 02-16-2014, 01:45 AM   #197
Unionwelder
Unionwelder's Avatar
Pulled the column to fix the 3ott shift issues I've been having( no 2nd or 3rd gear), got that repaired and shortened the column length. Not sure how well the linkage is gonna fit but ill tackle that tomorrow.
-Sterling
GIG EM' AGGIES!!!! WHOOOOOOP!!!!!
"Whether you think you can or think you can't, you're
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
Unionwelder is offline
Old 02-16-2014, 07:51 AM   #198
BruthaMan
US Army Veteran
BruthaMan's Avatar
I could hear that all the way down here! Very nice. Guess I'm not the only one with a '72 tag in a hundred mile radius!
BruthaMan is offline
Old 02-17-2014, 11:47 AM   #199
Lippyp
English Chevy Owner
Lippyp's Avatar
Washed the winters green slime off her, hopefully this year I'll get some time to do some serious work on getting her back on the road. Been accumulating parts for years now.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline
Old 02-17-2014, 01:16 PM   #200
BlacklandCamper
Got the intake bolted on, carb bolted on, cable bracket on, throttle and kickdown hooked up, and dizzy stabbed and set at TDC. Just need to change the oil, install the cap and wires, and toss some fuel in it so I can time it.
Also found the casting numbers on my heads.
They are 14014416.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline
Closed Thread
