Old 12-17-2017, 08:28 AM   #126
Greenlee
Greenlee's Avatar
Re: 1984 K30 Project Plow Truck
Looking good! Do you still need ballast with all that snow in the back?
We had enough snow here that it actually stuck to the ground for a few hours. Everyone went freaking crazy since we never see snow in this part of the country!
Greenlee is offline   Reply With Quote
Old 12-17-2017, 08:55 AM   #127
GM72K10
Next!
GM72K10's Avatar
Following
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 12-29-2017, 03:34 PM   #128
MTCK
MTCK's Avatar
Thanks greenlee, yeah added about 400 lbs of sand bags at the very back of the bed. Seems to have good traction and doesnt squat at all. I think I’m substantially lighter than I was with the flat bed and lift, but that is based purely on seat of the pants feel.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-16-2018, 06:24 PM   #129
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I’m still digging this 292 truck too Markus! Glad you haven’t ditch the cool 292 yet. Kinda sad you ditched the flatbed though.
Got a request for you, next time you have the hood open can you snap some clear pictures of the passenger’s side engine mount where it fastens to the frame? You know I have that 292 and I’m working deal to acquire a K5 and trying to determine if I can just move the V8 mounts around or if I need to go fish for 292 specific engine brackets.
Thanks!
DirtyLarry is offline   Reply With Quote
Old 03-17-2018, 03:42 AM   #130
MTCK
MTCK's Avatar
Larry, no problem on the pics. I’ll be doing my spring oil change soon and get those uploaded. Don’t worry - the 292 isn’t going anywhere. It has to be the best plow truck motor ever. Torque is immediate off idle and it is so smooth and linear.
The flat bed was literally falling apart. Rust took its toll. The new bed is super solid and I bet you change your mind when it’s all the same color! Lots of work coming this summer if time allows.
-Marcus
Project Plow Truck
Old 08-01-2018, 06:38 PM   #131
DirtyLarry
DirtyLarry's Avatar
Hey Marcus! Hope all is well. You’ve been pretty quiet for a while.
So, I’m getting close to start collecting pieces for my 292 project. When you get a minute can you snap some pictures of your 292 engine mounts and front crossmember so I can see what I need to look for as I go on a parts scavenger hunt? I seem to recall the engine crossmember is also different on the 4x4 trucks with 292s due to the offset engine mounts. Curious to see how yours looks compared to V8 crossmembers. This engine is going into a 1985 K5.
Thanks!
Old 08-02-2018, 03:15 AM   #132
MTCK
MTCK's Avatar
I’ve been way quiet! Work and the little guy are keeping me busy. Wife got me this sweet console for holding my coffee while I plow. I’ve also started to install and wore my beacon and flood lights, but progress is non-existent.
PS Larry check your email!
-Marcus
Project Plow Truck
Old 10-28-2018, 02:26 AM   #133
MTCK
MTCK's Avatar
Almost three months later.... beacon and floods are on the back rack and wired. I got a whelen switch panel and it is very well made and pretty sweet. 60 amp ignition switched relay feeds it and I have room for two more circuits: light bar facing front and probably some bumper lights in the rear. Way better than plowing in the dark!
-Marcus
Project Plow Truck
Old 10-28-2018, 02:27 AM   #134
MTCK
MTCK's Avatar
Aforementioned switch box.
-Marcus
Project Plow Truck
Old 10-28-2018, 02:30 AM   #135
MTCK
MTCK's Avatar
Also scored 5 new crack-free clearance marker lenses from the salvage yard.
-Marcus
Project Plow Truck
Old 10-28-2018, 08:42 PM   #136
COS399
COS399's Avatar
lights are good in your part of the world this time of the year. Light control box looks nice.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 02-27-2019, 09:50 PM   #137
1967KaiserM715
1967KaiserM715's Avatar
Hey, MTCK, if you could post pics of the passenger mount for the 292, information is very sxarce, I believe I may have found the correct bracket, but would like to verify.
My 292 is going into an '86 K30. Much appreciated.
1967KaiserM715 is offline   Reply With Quote
Old 02-27-2019, 10:22 PM   #138
Dads79GMC
Dads79GMC's Avatar
How did I miss this one, great build. It's nice to see a real truck doing real truck work!!!
Thanks Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 02-28-2019, 12:23 AM   #139
MTCK
MTCK's Avatar
Thanks guys. There is no life of leisure for the old trucks around my house...
Pardon the battery box for the 4D battery.
-Marcus
Project Plow Truck
Old 02-28-2019, 12:05 PM   #140
1967KaiserM715
Thanks, I thought that engine bracket was supposed to be different. Is the cross member design different then? Information for these 292's has been hard to find, and what information I have found is conflicting. Is that supposed to be the original engine to the truck?
Old 02-28-2019, 12:31 PM   #141
MTCK
MTCK's Avatar
Here’s the drivers side. The cross member looks the same to me, but DirtyLarry might be a good resource to ask. Yes it’s the original motor. I bought it from the original owner and have the build sheet on it. Best luck!
-Marcus
Project Plow Truck
Old 03-07-2019, 05:06 PM   #142
DirtyLarry
DirtyLarry's Avatar
Well, I couldn’t ever find OEM engine mounts for my 292 but I did find an aftermarket one from 12bolt.com that would work. Unfortunately, it blocks the fuel pump boss so you’d have to run an electric fuel pump. The good thing about that mount is the fact the engine drops right into the V8 position.
As far as my 292 project, it got canned. Over Christmas I opened up the engine as I was going to reseal it and freshen it up only to find it was a dud. The cam was wiped out and the main bearings were toast. Basically, it needed a full rebuilt that I wasn’t in the mood to do since I had a near drop in ready TBI 350 on the shop floor with harness plus the fact we don’t have any machine shops around here anymore to even get into an engine rebuild. I ended up selling the 292 the day after I advertised it on CL. BUT, I have my eyes on another 292 for a different project. I want a 292 rig, damn it!
Here is the 12bolt.com 292 engine bracket. They have driver’s side mounts in stock too
I see they also have another that doesn't block the fuel pump. I didn't notice this one before
Old 11-15-2019, 12:15 AM   #143
MTCK
MTCK's Avatar
Lots going on in the past six months. The plow truck got some maintenance: new water pump, functioning block heater, steering stabilizer, front light bar and backup lights under the bumper installed. We also moved to a new house with another garage bay and had a second kiddo. The plow truck gets more attention than the camper truck currently because it is for “work.”
-Marcus
Project Plow Truck
Old 11-15-2019, 12:17 AM   #144
MTCK
MTCK's Avatar
The extra light is great!
-Marcus
Project Plow Truck
Old 11-20-2019, 12:39 AM   #145
COS399
COS399's Avatar
Marcus,
Thanks for the updates and Congratulations on the new kiddo.
Old 11-20-2019, 04:55 AM   #146
MTCK
MTCK's Avatar
Thanks buddy! Eventful night at the ranch. Ran over my phone, kissed the wellhead and bruised my ego a bit. Always good to have a second one ton around and a wife who knows how to drive...
-Marcus
Project Plow Truck
Old 02-22-2020, 10:20 PM   #147
79oldj
That is the coolest 80s model i have ever seen! 292 K30 Awesome!
79oldj is offline   Reply With Quote
Old 03-25-2020, 04:27 AM   #148
MTCK
MTCK's Avatar
Thanks oldj! I like it. Been running the heck out of the plow truck like usual this winter. Hope she gets some maintenance and upgraded soon. I have a retro sound stereo that was a gift ready to go in and just got a new muffler and tailpipe kit too. 2.5” mandrel bet pipes and a magnaflow straight through muffler. Hoping it’s not too loud like the camper truck.
Got more than 6” of snow yesterday and it was wet and heavy.
-Marcus
Project Plow Truck
Old 03-25-2020, 04:28 AM   #149
MTCK
MTCK's Avatar
Going to need some bigger eq soon.
-Marcus
Project Plow Truck
Old 03-25-2020, 11:11 PM   #150
farmall
farmall's Avatar
What's eq?
I don't know how you can live like that. If it were me I would have to have a new Cat skid steer with a cab and heater included in with the mortgage. And maybe a large front end loader as well.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
