Old 01-17-2020, 07:48 PM   #1
RCon
Transmission swap question
I have a 72 C20 pickup with a th350. I want to change it to a 700r4 and want to know if anyone knows where i can get the new crossmember for it.
RCon is offline   Reply With Quote
Old 01-17-2020, 09:30 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Transmission swap question
https://www.partsgeek.com/chpjx2r-ch...on+Crossmember
Worked for me.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 01-18-2020, 11:27 AM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Transmission swap question
No need for a new crossmember it will work fine on your 350 but you will need the rubber mount for it. That it. I just did a 700-R4 in my 68. Slide the crossmember back and drilled 2 holes.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-18-2020, 11:34 AM   #4
71meangreenc10
Andy,
Post a pic of how it looks to access the rear pan bolts with a stock crossmember.
Smitty
71 C30 Wrecker
Old 01-18-2020, 10:36 PM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Transmission swap question
I will try and remember to do this tomorrow. From what I remember it's very tight but doable. I used this same setup on the 71 C 10 when I did the 700-R4 in it.
Old 01-20-2020, 09:22 AM   #6
Smitty
Smitty's Avatar
When I dis mine I trimmed the small horizontal flange on the front of the crossmember. Then added a plate inside the vertical to strengthen it. Gives needed space for access to rear pan bolts. Although the gusset probably wasn’t necessary. 15+ yrs. no issues.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
